Does workbench system let me modify geometry post-simulation
Old   March 12, 2010, 23:57
Default Does workbench system let me modify geometry post-simulation
rubenk is on a distinguished road
We are migrating to Ansys 12 CFD package from Fluent 6.3.
I would like to know if it is possible to actually update the geometry with workbench (includes design modeler) so as not to lose my boundary conditions, etc from my existing Fluent model or if this is a pipe dream. Original geometry was created using Gambit.
I got excited because I see that Star-CCM+ advertises
"post-process, update the geometry and automatically rerun the calculation, all within a single coherent environment..."
I thought maybe it is possible with the new ANSYS 12.1 product.
rubenk is offline   Reply With Quote
Old   March 13, 2010, 19:07
Default Of course...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Yes, it works well as long as the entity names are maintained... If you used IGES or something like that, the names get scrambled and there is nothing we could do...
If your names are the same (behind the scenes surface names get preserved with most geometry types) then the mesh params, bocos, etc. are all "parametric and persistent". You can replace the geometry in the DM tree and Workbench will perform all the same operations (geometry operations, meshing operations, solver setup and post operations) on the new geometry.
If an entity is missing from the new model (such as an outlet), you can just reapply that boco or mesh parameter (or add other ones) and then proceed.
If you have DesignXplorer, you can really start to play with the parameters... Create a DOE, post process, etc.
PSYMN is offline   Reply With Quote
geometry, post-processing, workbench
Workbench Simulation Grayed out - Not installed? Stewart Long Main CFD Forum 0 October 28, 2008 07:42
Need ideas-fuel discharge system Jan Main CFD Forum 0 October 9, 2006 05:27
CFX10 post, geometry parts not visible Claudia CFX 0 May 19, 2006 08:22
2D mesh in ANSYS 10.0 Workbench Frank Peters CFX 4 May 18, 2006 05:36
modify the geometry! RON CFX 3 June 2, 2003 14:30
