[ICEM] Geometry ignored on symmetry plane
Old   March 5, 2010, 21:51
Default Geometry ignored on symmetry plane
Kai
flyingk is on a distinguished road
Hi everyone,
I am trying to mesh a simple 3d wing half model with a symmetry plane. Octree works but Fluent does not seem to like the mesh... Thus I am trying to use the patch dependent mesher. Works fine on the wing but when I mesh the symmetry plane the mesh is strangely distorted and ignores the geometry at the leading and trailing edges ( see pics). I believe I have tried all options and also attached curve setting to the contact curve. Nothing changes the behaviour.
I can't attach the files because of size but will send them out if somebody could have a look. It's probably something simple but I am out of ideas... The same geometry work fine in CFX mesh but the control there is so limited. I also tried several import formats including the original Solidworks file.
Thanks for any advice.
Kai
flyingk is offline   Reply With Quote
Old   August 15, 2011, 12:05
LL
aweizazuji is on a distinguished road
Same question,hope someone help!
aweizazuji is offline   Reply With Quote
Old   August 16, 2011, 07:41
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
flyingk,
Octree works well because it doesn't mind if your CAD model isn't watertight and connected up nicely. However Patch Dependent surface mesh algorithms need the surfaces to be connected well, or it will not create a (usable) mesh.
Try to use the Build Diagnostic Topology function to fix your geometry. If you have single edges, the patch dependent algorithm will not work.
Stu
stuart23 is offline   Reply With Quote
geometry, icem, unstructured mesh
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge TWaung CFX 2 February 16, 2010 09:11
Symmetry plane help! (with schematic) Nate Siemens 1 October 11, 2007 11:46
Symmetry plane error in solver Santiago Orrego. CFX 6 January 31, 2007 08:09
ICEM and symmetry plane Roland CFX 3 September 13, 2006 09:38
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 08:16
