[GAMBIT] Meshing complex geometry (Hull)
Old   March 16, 2010, 13:49
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
they aren't connected.
upload your dbs file
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   March 16, 2010, 13:58
Vincent Meertens
vmeertens is on a distinguished road
Send a message via MSN to vmeertens
Regarding the colors they aren't connected, indeed. Should i connect them manually?
On what server can i upload the file? Or can i mail it to you? (the dbs file is 3Mb)
vmeertens is offline   Reply With Quote
Old   March 17, 2010, 02:46
-mAx-'s Avatar
Maxime Perelli
Ok I checked you model, and the volumes are connected, so it is ok from this side.
Now since you have meshed it, have you checked the max skew cells? (examine mesh icon and check how many cells exceed 0.9) There are sharp angles which makes failed some surface mesh.
Is the check-mesh in fluent ok?
Old   March 17, 2010, 04:40
Vincent Meertens
Thanks for doing this! Could you tell me how you did it, or send the file back?
I know the max skewness is to big in my mesh right now. Some off the cell exceed 0.95 (8 cells)
I'm trying to resolve this, but i think i will have to change (or smooth) the angle of the upperdeck.
The check mesh in fluents gives a to large skewness and aspect ratio.
Old   March 17, 2010, 05:11
-mAx-'s Avatar
Maxime Perelli
ok what you can do:
for each sharp angle (like the picture):
*create a vertex at location on one of the edges which generates sharp angle
*do the same for the other edges
*split each surface (here 2) with the 2 vertex you created
*merge each surface containing sharp angle with the hull surface (not the other surface with sharp angle)
*the sharp angle should dissapear, and the problem will be on the short edges (split from vertex). But this issue can you solve by refining the mesh around the edges
Old   March 25, 2010, 16:44
Vincent Meertens
Thanks to mAx this problem is solved!
There's a size function attached to the hull so the 'inner brick' can be meshed with Hex Core Native and the skew is limited to 0.92.
The outer brick is also meshed with Hex Core Native, so the total amount of cells is about 2 000 000.
I think almost everything is explained in the topic.
The major problems were:
Split the domain
Merge the surfaces of the hull
Try to limit the sharp angles by splitting the surfaces and merge the part with the sharp angle.
Use a SF to limit the skewness.
Thanks for al the help!
Vincent
Old   March 29, 2010, 11:24
Default Read file with command "NBLOCK and EBLOCK"
  #27
Carlos Andres Perez
caaperezan is on a distinguished road
I´m working with ICEM CFD, I´m importing mesh to ANSYS about disc spine but It generated *.txt. This file have commands i.e. "CMBLOCK, EBLOCK, NBLOCK" My cuestion is , Can to read these commands in APDL MECHANICAL of ANSYS
How do I do this?
Att Carlos Andres
caaperezan is offline   Reply With Quote
[GAMBIT] Trouble meshing complex VOF geometry RPJones ANSYS Meshing & Geometry 2 February 14, 2011 19:54
[GAMBIT] complex geometry meshing 1682333 ANSYS Meshing & Geometry 7 August 31, 2009 13:44
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 09:17
Gambit Meshing complex geometry Edwin FLUENT 2 July 19, 2006 16:02
Meshing a complex geometry AJG FLUENT 2 June 29, 2005 09:39
