[Other] ANSYS to Fluent mesh export in ASCII format
Like Tree21Likes
Old   November 3, 2015, 18:15
David Flemming
Davitt is on a distinguished road
Hello everyone,
I've recently read through this post as I am attempting to use fluent3DMeshToFoam to import a .msh file into OpenFOAM but after setting the the varaible for ASCII, the command still does not produce the mesh in OpenFOAM.
It just stops at Lexing...here is an image of the terminal
[IMG][/IMG]
Any help will be greatly appreciated,
Thank you,
Davitt
Davitt is offline   Reply With Quote
Old   April 21, 2016, 21:29
Lup Wai
chewlupwai is on a distinguished road
As mentioned in previous posts, changing environment doesn’t work in ANSYS v14 and above if you want to export .msh file as ASCII format. After a whole day of digging, I finally found the way, hope this helps:
Step 1: Tools -> Options -> Meshing -> Export
Step 2: Under ANSYS FLUENT, change Format of input files to “ASCII”
Step 3: Export as .msh format
Step 4: Run your fluent3DMeshToFoam to convert your mesh
Rodolfo Puraca likes this.
chewlupwai is offline   Reply With Quote
Old   July 12, 2018, 23:26
Default Set it in ANSYS Meshing
  #63
Ruiyan Chen
cryabroad is on a distinguished road
I know this is a very old post, just want to provide a little video I found. It's exactly what Lup Wai suggested, but you can see it in action.
https://www.youtube.com/watch?v=f9-GDWLKixg (Get .MSH Fluent Mesh File to Use in OpenFOAM w/o Having Fluent License)
At around 5' mark.
cryabroad is offline   Reply With Quote
Old   May 17, 2021, 07:20
Default Workbench 2020 r2
  #64
Mattia Samiolo
mattia_samiolo is on a distinguished road
To export the .msh file in ASCII format the shortest way (from ANSYS meshing) is:
File -> Option -> Meshing -> Export -> Format of input file (.msh)
Choose ASCII and then you can easily extract the file in ASCII format exporting the mesh.
mattia_samiolo is offline   Reply With Quote
Old   October 19, 2021, 21:13
Arturo Alanís
a.aralnu is on a distinguished road
Yes, this is the way to do it from fluent mesh program.
If you are working in ICEM CFD v 2020R2 you have to go to output mesh menu --> select solver --> fluent, set BC --> input file. In the input file menu just click the Write Binary File : NO. This writes the mesh file in ASCII.
Just tried this after looking it up for a couple hours and it works.
a.aralnu is offline   Reply With Quote
export ascii file with fluent Clementine FLUENT 3 August 2, 2012 10:52
Exporting structured mesh from ICEMCFD to Fluent? jeevan kumar FLUENT 1 January 23, 2012 12:21
how to export mesh file to Fluent sachin CFX 4 May 14, 2007 09:31
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
how to export mesh from ICEM CFD to Ansys siv CFX 10 March 23, 2006 09:19
