Exporting part names to Fluent
Old   February 20, 2010, 10:43
Default Exporting part names to Fluent
Malachy O'Rourke
morourke is on a distinguished road
I have generated a mesh in ICEM and exported it to Fluent. However when I read in the mesh I can not see the parts I created in ICEM (i.e. inlet, outlet, etc). I would appreciate if somebody could offer some help.
morourke is offline   Reply With Quote
Old   February 22, 2010, 12:36
Default should work...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Did you have shell elements in those parts?
Did you create bocos in those parts?
You must at least click on the bocos button and hit accept to save a default file, but you could also set things up more carefully, then you must make sure to save the project before outputting. The output operation is a batch operation that runs off the saved files, so saving is critical.
This usually works pretty well. Actually, the ICEM CFD ability to write fluent.msh files is 100% of the options available in the format.
PSYMN is offline   Reply With Quote
Exporting ANSYS Mesh to FLUENT murat FLUENT 0 June 29, 2007 18:22
Exporting mesh from Gambit to Fluent Becky FLUENT 1 January 11, 2005 14:01
Exporting ICEM Mesh into Fluent... Harmeet FLUENT 1 July 28, 2004 03:56
exporting iso-surface from fluent Fred FLUENT 0 September 5, 2001 06:24
Exporting Gambit to Fluent v4 R.Wilkins Main CFD Forum 2 July 21, 1999 17:05
