[ICEM] wing body tutorials, problem
Old   February 12, 2010, 06:19
Default wing body tutorials, problem
zhao xin
zxin is on a distinguished road
Hi, guys,
I got a trouble when doing the tutorials of ICEM, the wing body, hexa mesh. I followed the instructions and steps carefully. But the result I got is different from the mesh size that the tutorial shows. I got 40 millions nodes and hexas, after I set the surface mesh parameters as, maximum size to 300, height to 300 and height ratio to 1. This lead me can't even see the grid in the pre-mesh.
on the same edge, I got 3332 nodes, and tutorial shows only 115.
Hope somebody can help me with this rokie problem.
Thank you!
zxin is offline   Reply With Quote
Old   February 14, 2010, 19:05
Default not sure...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I am not sure what went wrong... perhaps you had something set finer than you thought. If you post the files (*.tin and *.blk), I could take a quick look.
In the mean time, you can fix the edge distribution manually
Use the middle icon to adjust edge distribution, select the edge and change the number of nodes to 115.
Simon
PSYMN is offline   Reply With Quote
Old   February 18, 2010, 06:08
zhao xin
Simon
Hi Simon,
Thank you for your information and sorry for this late reply.
I solved the problem by changing the number of nodes on the edge manually. But I still don't know why the default number of nodes get that high.
Because there is something wrong with my computer, the file lost. I will mesh it again and if the problem remains, I will post it to you and hope you can make a quick look. Thank you ^_^
Xin
Old   February 23, 2010, 11:04
Emanuele
nuovodna is on a distinguished road
OT Where can i found wing body tutorial?!?! Thanks FOUND IT (Help section of software)
nuovodna is offline   Reply With Quote
Old   March 9, 2010, 16:40
Conrad Lee
cylee is on a distinguished road
Originally Posted by zxin View Post
Hi, guys,
Thank you!
I am having a similar problem. I follow the surface mesh setup instructions to first set the size globally (300, 300, 1) then locally on the wing-body (50, 50, 1.4) and end up with 750 million nodes and hexas. The pre-mesh won't even generate because it is so large. Checking edge parameters on 25-130 I see that it has 3943 nodes instead of the expected 115. I've gone over the steps of the entire tutorial 3 times with the same result. I will try to set the edge parameters manually but would appreciate some help in finding out why I had the initial error to begin with.
Thanks,
Conrad Lee
cylee is offline   Reply With Quote
Old   March 16, 2010, 09:19
lehoang_mai's Avatar
User_CFD
lehoang_mai is on a distinguished road
I have an error as, how fix it, everybody?
A minor internal error has occurred.
You may continue to work but if problems arise they may be related to this error.
Try using the check/fix function to fix the problem
The following message was designed to aid developers fix the problem:
failed to allocate space for 140393388 nodes of 32 bytes each
lehoang_mai is offline   Reply With Quote
Old   March 16, 2010, 14:52
Default Too many nodes, check edge params.
PSYMN's Avatar
Simon Pereira
lehoang_mai
Your mesh is just too big (too many, 140 million, nodes) for your machine...
Chances are that something went wrong when you setup the sizes and things are really much finer than you think...
In the model tree, right click on edges and turn on the option for bunching... I am pretty sure you will find some edges with way too many nodes. Then use Blocking tab to adjust the edge parameters for those edges to have fewer nodes...
If you really did need 140 million nodes, then perhaps you should get a bigger 64 bit machine.
Simon
Old   May 2, 2010, 17:12
User_CFD
Thanks Simon!
Old   March 22, 2011, 02:05
Tony12 is on a distinguished road
I ran into the same problem, but I was able to considerably reduce the number of nodes by manually changing the number of nodes through bunching. Thanks Simon that really helped me out!
Tony
Tony12 is offline   Reply With Quote
Can't get good results on ahmed body research Michael Main CFD Forum 8 September 17, 2008 14:55
Laminar wing profiles and drag gregorv OpenFOAM Running, Solving & CFD 4 December 4, 2007 14:25
Simulate flow field of moving body by dynamic meshes luckyluke OpenFOAM Running, Solving & CFD 5 January 10, 2006 05:37
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 09:40
Problem about 3D blunt body high Re simulation David FLUENT 0 September 27, 2002 11:59
