Need help icem cfd
Like Tree1Likes
Old   June 27, 2011, 02:40
Default Plzz help: Meshing Manifolds
  #21
A-Vdia
ayush is on a distinguished road
I am meshing a simple manifold, I created INLETS and OUTLETS parts, with a single material body in the fluid domain. But I created the inlet and outlet seleting Surfaces (Breaking connectivity of the initial TRM_SRFACE) . Now when I change the initial geometry dimensions and then try to remesh the new geometry with the same replay file. The outlet part just wont get created, however INLET does. I am automating the meshing process. And this seems the final hurdle... PLZZ help..
I am using an IGES file to mesh the manifold (created via Surfaces option)
ayush is offline   Reply With Quote
Old   June 27, 2011, 06:51
Default Replay File
  #22
A-Vdia
I found a way around the problem, but that too has a misgiving, I now need to create a Replay file .. via a replay file ... Can that be done ?
Old   June 28, 2011, 14:46
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Yes, you can record the command to save a replay file in the replay file... so no problem... But why?
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   June 28, 2011, 22:56
A-Vdia
The reason I needed the replay file to record a replay file is,
the part OUTLETS I created via selection, wouldn't have the same feature names if say I ran the same replay file for a scaled version of the geometry, as I found out. i.e. if say every dimension of the same model were made 6 times (without creating something new in the geometry) I expected ICEM CFD to keep the names of the curves and points same as the previous model, for automation of the MESHING PROCESS.
But Alas ! that wasn't the way icem was working !! And since a replay file can capture all the feature names when I break connectivity of the Surfaces, I can use a bit of programming to extract the names from the replay file... I have done this without using replay files but using the tetin file of the model and it is working perfectly, but a replay file will cut my programming really short.... Please help !!
Summary :
Replay 1 : Model Scale 1
Outlet Selected feature : F_44 (say)
Replay 1 : Model Scale 6 (Dimensions made 6 times the orignal)
Outlet Selected Feature : F_48 (though I did nothing to the geometry, but scaled it, the feature name changed !)
Old   March 24, 2014, 14:04
Masoud
masoudmohammadian is on a distinguished road
Hello dear friend.
What is RMB and LMB in ICEM? Could you please explain it?
masoudmohammadian is offline   Reply With Quote
Old   January 31, 2017, 02:09
karthikeyan
rsskarthikeyan is on a distinguished road
Originally Posted by masoudmohammadian View Post
Hello dear friend.
Left mouse button stands for LMB and
right mouse button stands for RMB
rsskarthikeyan is offline   Reply With Quote
ICEM CFD Scripts Vinod Dhiman Main CFD Forum 2 February 17, 2010 11:56
Help for ICEM CFD - urgent Tuks CFX 3 February 8, 2010 04:32
ICEM CFD to CFX geometry and mesh Luca CFX 6 February 4, 2010 17:31
How about ICEM CFD M.Gao Main CFD Forum 1 November 15, 1999 05:15
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 13, 1999 00:27
