Help with GAMBIT modelling
Old   January 28, 2010, 11:20
Default Help with GAMBIT modelling
Faju
northdako is on a distinguished road
I'm doing an analysis of an open-window bus.... but i cant figure out huv to model the window... i'm relatively new to fluent... can anyone help me out.. please?? huw do i model the open part as part of the bus?? Plz help!!
northdako is offline   Reply With Quote
Old   February 1, 2010, 02:22
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
split the surface containing the windows, with the blue surfaces (windows)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 1, 2010, 02:32
Faju
tanx.... ive done that but den i get only a face r8?? but i need the bus as a volume... ive made one volume as the bigger cuboid minus the smaller cuboid (the bus)...now for the flow inside the bus i need to form the bus as a volume rt?? but i cant figure out to make a volume wid the open part (the window)
Old   February 1, 2010, 06:33
-mAx-'s Avatar
Maxime Perelli
hmm, and I assume your bus hasn't any thickness (you only have a surface between the volume inside the bus, and outside).
ok, you can do followings:
*go back to beginning
*delete the bus volume, but keep the outer surface
*create the window surfaces
*split window surfaces from bus-outer surface
*Create your computation domain, and split it with all the surfaces (outer surface + windows)
You can Mesh your model.
YOu only have to pay attention, while defining your BC.
You must define the outer surface (of the bus) as wall, the windows should be exported as Interior per default
Old   February 4, 2010, 05:13
Faju
thank u so much max.... u solved my problem
[GAMBIT] Gambit Modelling Guide PDF PLN Prasad ANSYS Meshing & Geometry 56 August 10, 2013 07:40
Modelling a synthetic jet for a 2-d flat plate using gambit gaurav ANSYS Meshing & Geometry 0 May 1, 2009 10:59
Modelling 3D elbow in Gambit Karthik FLUENT 2 September 4, 2008 10:39
Modelling in gambit Shanti V FLUENT 2 October 6, 2005 22:55
Modelling hull surface by Gambit 1.2 Ieria Giovanni FLUENT 0 February 23, 2000 05:03
