[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6
Old   January 26, 2010, 17:57
Default 3D boundary layer and meshing problem in GAMBIT 2.4.6
Prashanth
prashanthreddyh is on a distinguished road
Hi
I have a problem with boundary layer formation. Already created boundary layer is removed by the GAMBIT 2.4.6 while the meshing the volumes, it says that Unable to attach boundary layer on edge xxx.3 of face xxx.
I am modeling a free surface flow i.e. a canal, levee breach and flooding the surrounding area. I am trying to model the steady state conditions after the levee breach. The total area is divided into 23 volumes. The volumes 1 to 11 are solid blocks (they are houses in the flooded area) and remaining volumes 14 to 25 are fluid volumes. I would like to mesh all the fluid volumes but boundary layer is required in fluid volumes at least 14, 24 and 25. Top of the fluid volumes is free surface flow. The bottom of the fluid volumes is not even surface so meshing and creating boundary layers is challenging. Without the boundary layers I could mesh the fluid volumes with 2 cm volume meshing in this order and I could successfully export to Fluent
1) vol 24 Hex Wedge Cooper 0.02
2) vol 25 Hex Wedge Cooper 0.02
3) vol 14 Hex Wedge Cooper 0.02
4) vol 15 Hex Sub Map 0.02
5) vol 16 Hex Sub Map 0.02
6) vol 17 Hex Sub Map 0.02
7) vol 18 Hex Sub Map 0.02
8) vol 19 Hex Sub Map 0.02
9) vol 20 Hex Wedge Cooper 0.02
10) vol 21 Hex Wedge Cooper 0.02
11) vol 22 Hex Sub Map 0.02
12) vol 23 Hex Map 0.02
I have uploaded the journal file. Download link is http://rapidshare.de/files/49060728/2232e.jou.html
Please help me creating boundary layers and meshing. Any idea, advise and solution is greatly appreciated.
Advance thanks to you.
Prashanth
prashanthreddyh is offline   Reply With Quote
Old   December 20, 2011, 01:35
Mahdiyeh
m_kanani is on a distinguished road
Hi
I have a problem with BL method like you. Have you found any solution for this problem yet?
Please help me about this problem. thanks a lot.
m_kanani is offline   Reply With Quote
GAMBIT meshing problem for boundary layer Falah FLUENT 2 November 30, 2020 15:16
GAMBIT - problem with Boundary layer meshing MartinRei FLUENT 5 October 28, 2011 11:27
Boundary layer meshing problem in Gambit Crystal FLUENT 0 June 12, 2009 21:58
Boundary layer meshing problem in Gambit Crystal Main CFD Forum 0 June 12, 2009 15:32
GAMBIT problem with 3D Boundary Layer when meshing Anthony Haroutunian FLUENT 2 March 26, 2008 03:02
