[Other] ANSYS CFX-Meshing problem of a wind turbine blade
Old   January 8, 2010, 13:21
Exclamation ANSYS CFX-Meshing problem of a wind turbine blade
Zoe
Zoe Kyrou
Zoe is on a distinguished road
Hi there!
I am a student and I have undertaken a project on a wind turbine blade. I am using ANSYS Workbench 10 and I am trying to run simulations for a blade, which I designed in Rhinoceros program.
The first time I imported my drawing in ANSYS the mesh application ran just fine. After that, i had to rotate the blade in a different angle (that is the purpose of my project) and the mesh kept failing. The mesh parameters I have been using are: Type: constant, Maximum space length: 0.005. No matter how fine I make the mesh, it keeps giving me warnings that there are sharp edges and small angles in the blade design.
Does anyone have a clue what I can do to overcome this problem?
Zoe is offline   Reply With Quote
Old   July 14, 2010, 03:02
Default answer
Muhammad Omer Mughal
Muhammad Omer Mughal is on a distinguished road
dera the answer to your problem is that use face meshing in ANSYS CFx mesh and in face meshing use relative error method,specify the variables according to the length of your blades.
Muhammad Omer Mughal is offline   Reply With Quote
ansys workbench, mesh problem, wind turbine blade
How to create wind turbine blade in DesignModeler Atit CFX 5 December 26, 2012 07:13
Wind Velocity Profile in ANSYS CFX diluom CFX 7 December 10, 2009 23:50
how to make turbine blade in Ansys Blademodeler Usman CFX 3 January 29, 2008 05:53
wind turbine KADONED CFX 1 December 6, 2007 18:14
Meshing pitched blade turbine Racheal FLUENT 0 July 12, 2005 14:25
