January 4, 2010, 07:07 |
Changing default startup command
Sebastian Gatzka
Rep Power: 20 |
Hello World.
Can you tell me how I can change the default startup command for GAMBIT? I want to start with Code:
-r 2.4.6 -dev X11 Code:
-r 2.4.6
Schrödingers wife: "What did you do to the cat? It's half dead!" |
changing default unit in Gambit | NISHIKANT TAMRAKAR | FLUENT | 6 | May 20, 2016 01:22 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 04:41 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 21:45 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
