December 24, 2009, 19:15 |
Export mesh to Gridgen
Ali
Rep Power: 17 |
Hi everyone,
I have grid in Ansys ICEM and I want to export it into Pointwise Gridgen and there is not such option in ICEM mesh export part(as I know...). How can I do that? Regards, |
December 26, 2009, 04:22 |
Rep Power: 17 |
You can export your mesh from ICEM to CGNS and then import the CGNS file in Pointwise Gridgen if it is permitted by this one, else try to find other file format common to these two softs. |
January 2, 2010, 13:20 |
John Chawner
Rep Power: 18 |
Ali:
As Abou suggested, CGNS is always the first suggestion when moving data between two CFD codes. Since Gridgen's CGNS import is limited, I suggest exporting a CGNS file from ICEM and importing it into Pointwise. You don't say whether your grid is structured, unstructured or hybrid but depending on the type any of several neutral formats might work. For example, structured grids could be shared using PLOT3D and unstructured grids may be shared using FieldView unstructured (although I'm not certain that ICEM can read it). Hope this helps.
John Chawner / jrc@pointwise.com / www.pointwise.com Blog: http://blog.pointwise.com/ on Twitter: @jchawner |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
Two Ways FSI: How I can Export the Deformed Mesh back to the SolidWorks | ahmadkermani | CFX | 6 | March 8, 2016 04:29 |
Two Ways FSI: How I can Export the Deformed Mesh back to the SolidWorks | ahmadkermani | Main CFD Forum | 0 | August 13, 2009 23:02 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
mesh export | Hossam | FLUENT | 1 | May 5, 2006 13:28 |
