Some basic help PLEASE
Old   December 7, 2009, 05:59
Question Some basic help PLEASE
emarnchi is on a distinguished road
Hi, I'm starting with ANSYS Workbench and it's great, I managed to do some nice CFX analysis on some simple geometry. I love it.
There are, however, a few things that I don't understand. Please help me out.
1) If I create a sketch, e.g. a line, how do I CHANGE the attributes afterwards? Everything is gray. All I can change is the "extrude" and so on (I can also use parameters on these, which is the way to go). The solution for now is to edit a .js script that makes all the drawings from scratch in a given plane at once. Again, that can't be the way, there should be a possibility to edit the property of a line and regenerate what follows, right? Otherwise how can you do a 100% parametrized drawing?
2) I see that you can generate a script for the current plane. How can you generate a script for the ENTIRE workflow? that would be very useful for a parametric study of the project, since I would have full programmatic control over everything
Thanks a lot, I hope to see some good answers saying that all the points I have raised have a very simple solution
cheers
Emanuele
emarnchi is offline   Reply With Quote
Old   December 8, 2009, 12:50
Default Basic Help
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
1)If you click on the “sketch” in the model tree, and then use the sketch tab (on the right above the details panel) you will be able to edit it, add to it, etc. Then when you generate, all the other steps (extrude, etc) will simply be applied to the modified sketch.
2)Project level scripting is available in 12.1 and applies to the entire project. It is done in Python. Within the meshing application, you can select a number of parameters from any sketch or operation and manage those at the workbench level from the parameter bar. DX (DesignXplorer) is a very affordable workbench tool that hooks up to the parameter manager and can perform a DOE and run the series of designs for you. It generates response surfaces, tradeoff plots and other helpful graphics to help you understand how your parameters affect your design.
PSYMN is offline   Reply With Quote
Old   December 8, 2009, 12:52
Default thanks!
thanks a lot!
ansys 12, cfx, designmodeler, selection
What is the Basic Calculation of Lift Coef In Modelling 2D?? teguhtf FLUENT 0 October 14, 2009 05:52
Programming C, Basic george Main CFD Forum 3 September 12, 2006 23:42
Best method to setup a basic windtunnel Justin FLUENT 0 July 25, 2006 23:24
Appropriate flow velocity for basic 2d analysis Lukasz Mosakowski FLUENT 1 February 14, 2006 09:58
Basic CFD Book W. Miah Main CFD Forum 5 August 27, 1999 17:06
