[GAMBIT] Canīt start GAMBIT
Like Tree3Likes
Old   November 13, 2009, 11:52
Red face Canīt start GAMBIT
andre alho
zalho is on a distinguished road
Hi...
this is the first time that i'm using gambit to build a mesh to fluent...
but when i try to start gambit and start a project an error appear and i can't open the display...
the error is:
>>Locating Exceed installation ...
>>gambit failed in locating Exceed installation on your system.
>>Please try to start Exceed manually before you run gambit.
>>Starting C:\Programas\Fluent\Fluent.Inc\gambit2.3.16\ntx86\ gambit.exe >>-device open -id nozzle -new ...
>>Gambit build SP2006032921.
>>Warning : The current transport does not permit the attempted TCPIP >>connection.
>>TRANS(SocketINETGetAddr): tnamebysocket() failed
>>TRANS(SocketINETConnect): TRANS(SocketINETGetAddr) () failed
>>TRANS(Open): transport open failed for tcp/shibatronic:0
>>Unable to open display
what can i do to make GAMBIT work??
help me
zalho is offline   Reply With Quote
Old   November 13, 2009, 19:14
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Hi zalho,
In some ver of GAMBIT, EXCEED can run simultaneous When we active GAMBIT. But in some version, you must open EXCEED Manually file before you open GAMBIT.
Hope it helps
teguhtf
Now Or Never!!!
teguhtf is offline   Reply With Quote
Old   November 14, 2009, 16:06
Thumbs up
andre alho
Originally Posted by teguhtf View Post
Hi zalho,
Hope it helps
teguhtf
thanks teguh
GAMBIT is working...
Old   November 16, 2009, 00:55
Default @Zalho
Sanket Ghatnekar
oxidising agent is on a distinguished road
Hi, hope you have succeeded in running gambit.?
If not please try the procedure below. I had xactly the same problem. It easily worked for me as per this procedure.
(1) Start > Hummingbird Connectivity > Exceed > Exceed (Appln will open and u will see Exceed on task bar)
(2) R-click (Exceed on task bar) > Tools > Session Startup > New (Untitled X-session window will open)
(3) Click Directory.. > Select the folder where you have installed Gambit(generally the folder is Fluent.Inc) > Select gambit2.3.16 > OK
(4) Click New Program > Select Windows App > OK (Untitled Wstart window will open)
(5) Click Browse > Select Gambit ".exe" file > Select Run : Normal Mode > Run! (this will launch gambit application successfully)
(6) Set the working directory in the application > Run
(Gambit is launched / runs successful)
Njoy Gambit & Beer together.
Regards,
Oxidising Agent (sanketssg@gmail.com)
oxidising agent is offline   Reply With Quote
Old   February 7, 2010, 00:39
Devesh Baghel
devesh.baghel is on a distinguished road
Hii All.....
I am facing the same problem as described above. I tried to follow the procedure posted by sanket (oxidizing agent)......
currently I am using gambit 2.4.6 & Hummingbird 11.0 with exceed 6.0 on 32 bit machine. The solution suggested by sanket, i followed but wasn't able to get 3rd & 4th step, which Directory it was asking about. I was just able to open new Xsession on Gambit only.
i have been try to install Gambit so many times,,,but unable to get solution. Please someone help me & i am sorry if I am doing any silly mistake.
thanks alot
devesh.baghel is offline   Reply With Quote
Old   February 7, 2010, 02:41
Default @ Devesh
Sanket Ghatnekar
U have to give the path of the folder where Gambit is installed.When you click ok then select Gambit.exe file as application which is to be opened using Exceed.
Cheers
OA
Old   February 8, 2010, 03:00
Default @ oa
Devesh Baghel
Hi sanket,
Thanks for your reply. I stuckup at 2nd point, where you open Exceed (Right click)-->session start-->new......here its asking any .xs file.....so I am not very clear about this 2nd step.
so i am not able to resolve 2nd step as well unable to move for 3rd & 4th step also. Which directory path you were telling about....
please, your suggestions would be really appreciable.
thanks alot....
Old   February 8, 2010, 08:25
Default @ Devesh
Sanket Ghatnekar
Hi..
I got your problem.
Do as I say Now.
Start Exceed.
RClick on exceed on task bar. > Tools > "Session Startup" > New
Click the "Directory" tab and follow the rest of the procedure.
Set the path of directory the same where Gambit is installed.
Rest all is the same as in the post.
Cheers.
OA
Old   February 8, 2010, 08:35
Default @ Devesh
Sanket Ghatnekar
What u seem to have done is
RClick on Exceed > Client Startup > New...
Then only the .xs file required, but it is only used to restore the client session closed previously.
Correct me if Im wrong.(I hope Im not )
Cheers
OA
Old   February 9, 2010, 06:09
bouasam
mekkisam is on a distinguished road
For step 1 and 2 ery clear and very easy but for
Step 3 it isn’t clear at all, let me say it’s a nightmare
After step 1 and 2 we have an opened Untitled X-session window
Click the "Directory" Where is the "Directory" I don’t see it any where ? can you be more explicit. Is it in the opened Untitled X-session window or have I to make a new R click ? Help!!!
Step (4) Click New Program > where hae I to do that in the window below or I make a new R click ????
Make life easier for us it’s too complicated!
Thanks in advance for your help.
mekkisam is offline   Reply With Quote
Old   February 9, 2010, 09:55
Default @ All
  #11
Sanket Ghatnekar
Hey Guys,
I sincerely apologize for a very silly mistake (from my side) in interpreting all your problems.
I have uploaded the procedure compatible only for HummingBird / Exceed 9.0 and not Exceed 6.0 or any other combination.However I'll work out the same for other versions soon and upload the correct procedure.
I'm very sorry I couldnt figure this out very soon.Please excuse for the inconvenience.
Apologies again.
OA
Old   February 11, 2010, 03:28
Default Gambit
  #12
Carlos Ventura
cventura is on a distinguished road
Dear all,
Just have a few questions I was hoping you could help me with:
1) Is Gambit still available? As far as I know it was discontinued by ANSYS, and the licences no longer work.
2) How did you managed to keep it working? Was Gambit made available?
3) In case it is not available, is there any way to read the database files (*.dbs) with any other program?
I used Gambit for a few years and I am struggling to use a different software to produce a mesh (*.msh) file to use with Fluent.
Thank you.
Carlos Ventura
cventura is offline   Reply With Quote
Old   February 11, 2010, 08:17
Default @ Cventura
  #13
Sanket Ghatnekar
Hey..
"1) Is Gambit still available? As far as I know it was discontinued by ANSYS, and the licences no longer work.
I have no idea about this.As for my posts here, I have encountered such problems while handling these packages in an educational institute giving training in CFD.We still are using Fluent 6 Gambit 2.3.16 ANSYS ICEM CFD 10
ANSYS CFX 10.
The later versions might have been modified without Gambit license.
"3) In case it is not available, is there any way to read the database files (*.dbs) with any other program?"
Again I dont know about this.However now the question has been pooped out I'll search for the same.
Cheers.
OA
Old   February 11, 2010, 20:29
Carlos Ventura
Thank you Sanket,
I am using ANSYS 12 (Academic Licence) and Gambit is definitely not part of the package. Unfortunately for me, the geometry-meshing-boundary conditions set up procedure seems to be much different when using this latest package. I was simply to used to the "Gambit way of thinking"!
I am trying to get the work done with ICEM CFD which seems to be a very interesting tool, with lots of capabilities.
Hope to hear from you soon.
Cheers!
Carlos Ventura
Old   May 13, 2010, 23:41
abbasmh10 is on a distinguished road
hi oxidising agent ,,,,i m facing the same problem since i m using exceed 6. i have the following error:
Starting C:\Fluent.Inc\gambit2.3.16\ntx86\gambit.exe -device open -id default_id4812 -new ...
Warning : The current transport does not permit the attempted TCPIP connection.
TRANS(Open): transport open failed for tcp/mohamed-abbas:0
although the exceed is opened manually...still i cant have the gambit working. i really appreciate ur help and thank you in advance
abbasmh10 is offline   Reply With Quote
Old   June 4, 2011, 15:11
pedro gonzalez
pedrin84 is on a distinguished road
Hi, I'm working with Ansys Workbench 12.0 design modeler, building geometries there. But I need to export these geometries to Gambit 2.4.6 for the meshing y to make a multiblock grid and then export the mesh to ansys fluent 12.0. is this possible?. can I to install Ansys gambit 2.4.6 with the ANSYS 12.0 12.0 together?
pedrin84 is offline   Reply With Quote
Old   May 21, 2012, 17:28
Default Open shell
  #17
Ershad Amini
ershad is on a distinguished road
hi
how can I make an open shell (Cube) in gambit?
the fluid goes out from the upper face and I don't want to define any boundary conditions on the upper face.
can I create a face close to the upper face of Cube and then subtract them?
so the upper face is very thin but the cube is open from top
ershad is offline   Reply With Quote
Old   August 28, 2013, 10:45
Waseem Abbas
waseemabbas is on a distinguished road
Regards,
Hi dear !
I did the same as u posted but i received the error that" gBase32.dll file is missing from your computer".
And if i run exceed manaullay and gambit after wards i recieve:
Starting C:\Fluent.Inc\gambit2.3.16\ntx86\gambit.exe -device open -id default_id3832 -new ...
*** Server node is down or not responding
FATAL ERROR: Could not obtain valid license authorization
please help me ASAP
Regards
waseemabbas is offline   Reply With Quote
Old   April 8, 2019, 02:05
Smile I don't Know Where the Links to Download Exceed13 and I cannot Run Gambit 2.4.6
  #19
Luqman
GeneralThanos is on a distinguished road
Hey there its been 2019 already,
if Any one of You can Read this Comment Post
I really need to Run and Use Gambit 2.4.6 to fix my Mesh geometry of Real Full Scale Boiler for my Final Year Project.
My Problems are:
1). I don't Know where to Download HummingBird Exceed 13, I have searched all over the internet and its keeps giving me fake or useless Link.
2).I already Install Gambit version 2.4.6 But When i Tried to Launched it keep giving me error Message. Belows are the Message stated:
Launching Exceed 11 ...
Starting C:\Fluent.Inc\gambit2.4.6\ntx86\gambit.exe -device open -id default_id5564 -new ...
FATAL ERROR: Could not obtain valid license authorization.
Total of 0.03 cpu second(s), 102400 maximum memory.
See the system adminstrator about starting the server, or
make sure the you're referring to the right host (see LM_LICENSE_FILE)
Feature: gambit
Hostname: shahril
License path: C:\Fluent.Inc\license\ntx86\..\license.dat
FLEXlm error: -96,7. System Error: 11004 "WinSock: Valid name, but no record (NO_ADDRESS)"
For further information, refer to the FLEXlm End User Manual,
available at "www.macrovision.com".
Feature: gambit-addon
Hostname: shahril
Can Anyone who read these comment help me with Clear, Specific and Details step by step Solution procedure on how to fix this error? I would really like to appreciate your generous help and Would like to thanks you in Advances
GeneralThanos is offline   Reply With Quote
not start gambit Dorain FLUENT 4 November 14, 2009 15:35
cannot start gambit "set environment error" frank FLUENT 18 November 14, 2009 15:31
[GAMBIT] Gambit start win vista? ferranpm ANSYS Meshing & Geometry 1 June 8, 2009 17:23
start gambit KS FLUENT 3 April 28, 2008 04:50
GAMBIT start CDK FLUENT 2 June 1, 2002 03:56
