problem importing solidworks file into gambit
Old   September 15, 2009, 07:41
Default [GAMBIT] problem importing solidworks file into gambit
airakaz
mzack1104 is on a distinguished road
as stated, i'm using solidworks 2009 with gambit version 2.2.30..
i already save it in acis format, but when i'm import in gambit, i got this error:
"ACIS error 50005, save file is from a later version of ACIS"
than, i try save it in parasolid format, but i got different problem:
"ERROR: translation requires license features geom- trans"
anyone? or i need to use the latest version of gambit?? thanks everyone...
mzack1104 is offline   Reply With Quote
Old   September 16, 2009, 12:20
Default ACIS version.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Check your acis versions...
It may be that Gambit only supports up to acis 18.0. I don't recall the exact number off the top of my head.
your Solidworks 2009 may be outputting ACIS 18.3 or 19 or 20 or somethin in that range (> than what is supported by Gambit import).
The solution is to look into Solidworks to see if you can export an older format of ACIS.
PSYMN is offline   Reply With Quote
Old   September 16, 2009, 13:44
airakaz
thanks for the reply...you mean I need to create an acis file in gambit than try open it in solidworks?? quite confusing here
Old   September 16, 2009, 17:01
Default Output older format from Solidworks 2009.
PSYMN's Avatar
Simon Pereira
Nope, I mean look into Solidworks to see if there are options for what version of ACIS you output. See if Solidworks 2009 has an option to output older formats of ACIS.
If you output an older ACIS format (18.0 or older) from Solidworks 2009, then Gambit will be able to read it.
Old   September 17, 2009, 12:27
airakaz
Ok, already can. Thanks PSYMN. I just follow your advise and save it to older version of ACIS, I save it on version 12.
Thanks again!
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 05:26
Solidworks IGS to Gambit Problem Mustafa Ayad FLUENT 8 January 18, 2009 13:21
Importing Mesh file to Gambit Sri FLUENT 0 February 28, 2007 11:26
importing solidworks2003 file to gambit 1.2 utku FLUENT 3 June 3, 2004 05:13
File Size Exceeded problem in GAMBIT Prateep Chatterjee FLUENT 3 February 9, 2000 22:31
