August 13, 2009, 07:40 |
[ICEM] Applying surface mesh settings
Stuart
Rep Power: 26 |
Probably a simple question but anyway. I've selected some surfaces in the Surface Mesh Setup and have applied a maximum size. But I now want to have a smaller tetra size on these surfaces instead. But now when I open Surface Mesh Setup I have to reselect all the surfaces again and type in all the values - rather than just modify the single value I need to. It's as if I was starting at the beginning again. There must be a feature, like in CFX-Mesh, that lists all the surface and edge sizing parameters so you only have to choose that and it recalls all the parameters. Thanks |
August 21, 2009, 03:16 |
Stuart
Rep Power: 26 |
Thanks PSYMN.
[Netgen] Volume mesh instead of surface mesh | phan | OpenFOAM Meshing & Mesh Conversion | 4 | October 18, 2009 18:17 |
Mesh generation from surface model | wei | Siemens | 2 | April 24, 2009 03:33 |
Mesh @ Free Surface | MAB | CFX | 7 | May 29, 2008 05:48 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 13:21 |
Interpolating volume data onto quad surface mesh | N.R. | CFX | 6 | June 7, 2007 09:15 |
