[GAMBIT] Problem with split option
Old   January 21, 2014, 02:45
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
did you see this tutorial: https://www.sharcnet.ca/Software/Flu.../tg/node23.htm
I think you have to set your periodic BC with mass flow rate (as you already did), but I am not agree as you writing that du/dy= 0.
If you impose the massflow, then in the middle (0.5*l1) of your domain you have the critical section and your fluid will accelerate for maintaining same massflow.
Do you already have some results? can you display the velocity distribution?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   January 21, 2014, 04:17
Default Concept of periodic conditions
  #22
myaccount is on a distinguished road
Hi
Thanks for the response.
1.I have gone through the tutorial you suggested before starting my work.
2.I have done the tutorial for the developed flow through pipes.
for both of the above cases,same periodic conditions with pressure drop will be given.
In the second case,there is no change in the velocity profile (du/dy=0) after simulation.
In the first case,du/dy should not be the same.But we follow the same procedure of giving periodic conditions as that was done for case2.
How are this happening?
myaccount is offline   Reply With Quote
Old   January 21, 2014, 04:43
-mAx-'s Avatar
Maxime Perelli
display velocity and pressure distribution
Old   January 21, 2014, 05:49
  #24
Hi
Thanks for the reply.Please find attached the contours of X velocity,and pressure. mass flow rate is 0.0003575kg/s
Old   January 21, 2014, 06:12
-mAx-'s Avatar
Maxime Perelli
if you set the max velocity very low in the scale , do you see any velocity between all your squares?
Old   January 22, 2014, 05:07
  #26
Hi MAx,
How can we use same periodic conditions to
1.flow with a pressure drop,which is geometrically periodic in nature,and is not fully developed(like the model in fig 4.2 which I use for simulation).
and also to
2.Flow with a pressure drop,and fully developed flow(like fully developed flow through circular pipe)
Iam getting confused.
Old   January 22, 2014, 05:44
-mAx-'s Avatar
Maxime Perelli
I don't know.
I am not experienced with periodic flow.
Did you check if you get velocity distribution between your solid squares ?
Old   January 22, 2014, 06:00
Max, I also have one more doubt.. I am studying the heat transfer rate within an isothermal medium which is not moving(still) and it s at temp T1. The medium is confined within two large black isothermal walls of temp T2.
If we have to specify a wall as isothermAL, we can just give the value of the temperature in boundary conditions>>edit>>thermal >>thermal conditions>>temperature....
Am i right??
And if we want to specify a medium (fluid /solid) as isothermal, how to give a specified temperature for that? Because in boundary conditions panel, for solid or fluid, we can only edit the name and nothing else.. plssssssssssss tell me how to specify a still medium as isothermal... ?? Do we have to specify it in reference values section ?? or do we have to give it under cell zone conditions>>edit>>Fixed values>>Temperature ???
I tried it with fixed value once an as i am wrking in radiation heat transfer problems, i dont think I am right...
plsssssssssssss give me ur suggestions, max... I badly need it..
Old   January 22, 2014, 06:11
-mAx-'s Avatar
Maxime Perelli
I suggest you to open a new thread in the fluent subforum
You will have more chance to have answer of your thermal question
Old   March 25, 2014, 01:00
Default pressure drop in periodic flow
  #30
Hi Max,
I have simulated flow over solids through a channel.I have applied periodic boundary conditions at the inlet and exit of the pipe. Can I use the pressure drop indicated in periodic boundary conditions menu after the convergence of the case as pressure drop /L for my further work?
Can you please clarify.
gambit, geometry
Error message: Insufficient Catalogue Size Paresh Jain CFX 33 August 16, 2024 06:09
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
Multi Phase option problem.... Christos Sfyris Siemens 1 May 22, 2003 08:53
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
