August 6, 2009, 15:48 |
Solidworks + CFX - Mesh
fabio
Rep Power: 17 |
What is the best form os defining regions in a solidworks drawing? What im trying to do is the same commando as the Extrude-> Imprint Face of the Design Modeler but i cant find a similar command in Solidworks? Anyone can help me? Thanks |
August 12, 2009, 00:13 |
you dont find the extrude operation in solidworks?
August 12, 2009, 11:13 |
fabio
Rep Power: 17 |
yes, but in solidworks, extrude only add or remove material. The option Imprint Faces is not avaliable. There is a feature that creates a surface from a sketch, but if you use it, cfx-mesh cant open the geometry file
August 12, 2009, 11:19 |
fabio
Rep Power: 17 |
In fact, many people i know use extrude with 1mm depth, only to demarcate a region, but this gives too much problem with the mesh, bcause mesh will be to refined in that region and i wanted just a roght mesh
August 12, 2009, 16:26 |
ohh i see ,sorry man i didint use desing modeler, just for combine solid bodies and make it one before enter to the cfx-mesh. and i understend very well thats extruction of 1mm..i have in my model 832 louvers(in a can combustor) with only 3mm!..my mesh its of 1.7millions of elements
but you want to create a surface? frome a sketch? solidworks has that operation..go to Insert->surface-> and then you have allot of options to create a surface. do you have any experience with cfx-mesh? im really having a problem with the mesh. best regards |
August 12, 2009, 16:28 |
ohhh...if you use the surface operation in solidworks, cfx-mesh cant open the geometry?
August 13, 2009, 11:19 |
fabio
Rep Power: 17 |
No, cfx-mesh wont read the geometry if you use surface operations in solidwokrs. I found that split line can do this, but slip line command cant be patterned!
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
Exporting mesh to CFX Pre | Usman Ali | CFX | 4 | October 22, 2007 12:09 |
Import Gridgen Mesh V15 to CFX 10 | Christina | CFX | 3 | August 1, 2006 10:06 |
Mesh from ICEM CFD to CFX ! Error ! Why ? Thanks ! | Vu Trinh Tuan | CFX | 11 | March 28, 2005 20:04 |
importing mesh from ICEM CFD into CFX 5 | Jay | CFX | 2 | November 12, 2002 14:46 |
