[TGrid] "Cannot combine different thread classes" |
July 28, 2009, 16:51 |
Elaine Schreiber
Rep Power: 17 |
I received this error trying to grow prism layers in TGRID using "Auto Mesh."
I had selected to not retriangulate, and to "grow individually". If anyone has seen this error before and has a solution, please let me know! |
April 11, 2013, 12:57 |
Hi, your question is already quite old, but I thought maybe sb. else is going to have this problem in future also, as I did....
I recieved the same error message as you did, although, I grew the inflations with retriangulation and not individually. The problem with my geometry was, that I had quite steep angles between face-zones with prism-layers and face-zones without prism-layers. Though, I recieved prism-layers, along one edge, which have partly been projected to the adjacent face-zone and partly not! So TGrid built a prism-side, whereever the angle, between inflated face-zone and not inflated face-zone, was too steep to project the prism to the adjacent face-zone. Apparently this arises a problems within the tet generation. In the picture you can see: green -> face-zone without inflations purple -> face-zone with inflations light blue -> prism-side As you can see the prism-side appears at positions where the angle is too steep to project it on the green face zone The gap between the green face-zone and the purple face-zone is the area, where the prism-layers have been projected properly! This angle can be changed in the prism settings, in the project tab, by changing the "Max Adjacent Zone Angle". I know this does not describe or explain exactly your problem, but it gives a good hint, where the error may be! cheers |
prisms, tgrid |
udf problem | jane | Fluent UDF and Scheme Programming | 37 | February 20, 2018 05:17 |
Guide: Getting Started with the CFD Online Discussion Forums | pete | Site Help, Feedback & Discussions | 8 | July 29, 2016 06:00 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 15:37 |
Accessing cell thread from a boundary face thread? | Vishal | FLUENT | 2 | March 21, 2006 08:29 |
thread facet cell in flunt | peter | FLUENT | 2 | September 27, 2005 23:16 |
