Mesh Generation Output Format
Old   July 20, 2009, 15:50
Default Mesh Generation Output Format
Ali
ali987 is on a distinguished road
Hi everyone,
I'm looking for a software which be capable of making hybrid meshes and it can export meshing information in a straight forward format (i want to call this output file in matlab). and another important thing... it also specify "local number" and "global number" of nodes. does ANSYS do these?
Thanks,
ali987 is offline   Reply With Quote
Old   July 20, 2009, 16:35
Default ICEM CFD is famous for its flexible output
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
ICEM CFD supports hybrid meshing and can output in over 100 formats. It is likely that one of those formats will be in a format you could use.
For more specifics on these output formats...
http://www.ansys.com/products/icemcfd.asp
And got to the Output interfaces... At the bottom of that page you will find a table of supported solvers.
http://www.ansys.com/products/icemcf...rfaces/toc.htm
You can click on each of these to get info about the format.
Have fun.
PSYMN is offline   Reply With Quote
Mesh generation software is needed H.Dou Main CFD Forum 12 May 4, 2011 16:20
mesh generation problem Ellen FLUENT 7 February 18, 2009 22:20
mesh generation problem giyong Siemens 2 May 12, 2007 10:08
Hybrid mesh generation Fred Siemens 0 July 7, 2006 09:00
Beginner question – mesh generation. Oleg Melnik Siemens 2 February 26, 2001 03:39
