July 15, 2009, 05:58 |
Workbench ANSYS12.0 geometry&mesh
I'm a new user to ansys workbench 12.0. I created a 3D geometry, and i would like to make a 2D geometry out of it. I used some Slices and Body Op>Delete and Thin (with thickness and face offset set to 0) to get only the face of interest, which lies in the XY plane. I read in a discussion that the next step is to extrude or revolve my face on a short distance: 1 element. But I'm facing a problem: I can not make any extrusion or revolve operation when my bodies are 'Surface Bodies'. So i tried to give a small non-zero value to the 'thin' operation, but this does not give the proper result. Further, when I open the meshing interface, I can not select 'Edit in CFX-Mesh' anymore. So if someone could help or explain me a smarter way to go to a 2D geometry analysis, starting form a 3D geometry. Thank you. lhorion. |
July 16, 2009, 14:43 |
Solver?
Simon Pereira
Rep Power: 47 |
If your solver is Fluent, the 2D cut is fine. Just set the mesher setting to 2D...
If you solver is CFX, then you can extract a sketch and extrude it to get the 2.5D (one cell thick). Perhaps you could contact tech supp at 1-800-937-3321 to get help with this (I am not as good at DM as I should be yet). |
2dto3d, ansys12, designmodeler, geometry |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 10:23 |
Macro command combatibility ANSYS workbench | Tassos | CFX | 6 | January 13, 2014 05:19 |
ICEM CFD in Workbench | marek | CFX | 1 | February 15, 2008 11:35 |
Workbench Transient | Omer | CFX | 0 | January 15, 2007 15:21 |
Bi-directional FSI using Workbench | Stuman | CFX | 0 | April 5, 2006 20:31 |
