[Other] Workbench non-manifold body
Old   July 6, 2009, 20:27
Default Workbench non-manifold body
Adam Loesch
aloesch is on a distinguished road
I am attempting to make a CFD mesh in Workbench. In the DesignModeler, I import my igs surface body and create a primitive prism. When I try to do a Boolean subtract of the surface body from the solid prism, the operation fails with a "Error: Operation would result in non-manifold bodies." What exactly does this mean, and what type of corrective action can/should I implement?
aloesch is offline   Reply With Quote
Old   July 7, 2009, 11:39
Default Baffles me.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
DesignModeler does not yet support the subtraction of a surface from a solid (aka, a baffle). This is coming at 12.1 (due out in Q4 2009).
If your surface body was actually supposed to be a closed solid, you will need to sew it into a solid first. Then subtract the solid from the primative solid.
If you were trying to have a baffle, you have several options. You could use it to completely chop the primative solid; you will need add some other surfaces to make the segmentation complete and then adjust the contact to block flow only along your baffle… I haven’t actually done that myself, but I heard it was possible. Another option is to extrude the zero thickness wall into a thin wall. You can then subtract this thin solid from the primative solid. This may better reflect your actual model, but the thin edge may raise your mesh count and/or reduce your quality.
Simon
PSYMN is offline   Reply With Quote
Old   July 3, 2013, 20:05
Default Non-manifold bodies
Waqas
Wiki is on a distinguished road
I have made a wind turbine model but in ANSYS design modellor, I am constantly receiving an error message "operation results in non-manifold bodies". Could anyone suggest me a remedial action? Thank you
Wiki is offline   Reply With Quote
Old   July 4, 2013, 16:40
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
is it during the boolean operation ?
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
bodies, body, non-manifold, workbench
ANSYS Workbench on "Uncertified" Linux Distros hsr CFX 289 April 20, 2023 10:23
Macro command combatibility ANSYS workbench Tassos CFX 6 January 13, 2014 05:19
Body force at the cell face Souviktor Fluent UDF and Scheme Programming 0 March 31, 2009 09:54
Workbench Transient Omer CFX 0 January 15, 2007 15:21
allowable body size in ANSYS Workbench 8.1 Atit Koonsrisuk CFX 1 January 5, 2005 13:40
