June 18, 2009, 23:28 |
error meshing edges
Rep Power: 17 |
Friends
I am using ICEM-CFD for making geometry and meshing.It is giving an error as "error in meshing edges".but i can able to finish the meshing.Will this error message have any influence while running in Fluent??. How to rectify this???????? or final check in ICEM...... While running this mesh in Fluent some divergence is detected in AMG solver. Is this due to the meshing error shown in ICEM-CFD??? expecting a solution.......................... Thanks Siva |
June 19, 2009, 10:09 |
Run mesh checks to be sure.
Simon Pereira
Rep Power: 47 |
Run thru Edit Mesh => Check Mesh and also check Quality... if you pass, you should be fine from a mesh point of view.
If the error were serious (such as missing edges on a 2D model), you would get an error message as soon as you got into Fluent (null pointer error I think). Fluent checks the mesh before you run it to make sure it has complete perimeters for bocos, and the mesh passes minimum requirements. It will warn you if it doesnt. However, you can still get divergence for poor mesh quality in a critical area or bad bocos, or perhaps you need to add something like an extenstion to the outlet pipe to prevent recirculation or other problems. I dont' think that "meshing edges" error is your problem. |
setting boundary conditions on internal edges | Renate Stump | FLUENT | 4 | November 7, 2008 10:55 |
Edges in Gambit | Naghman Khan | FLUENT | 3 | October 3, 2007 06:36 |
gambit: mesh edges, change direction | Ralf Schmidt | FLUENT | 2 | August 29, 2006 10:55 |
Simple Meshed Edges Problem | Rich | Main CFD Forum | 1 | February 9, 2005 01:38 |
Deleting Edges in Gambit | Alberto Schroth | FLUENT | 4 | May 31, 2000 14:15 |
