[GAMBIT] NACA0012 meshing problem
Old   June 18, 2009, 23:15
Unhappy NACA0012 meshing problem
parvez
parvez2683 is on a distinguished road
HI friends,
I am new to the gambit. I am trying to mesh NACA0012 with chord length of 2.My farfields are 50C from the airfoil. I have followed the cornell tutorials. Everything goes well except the last part when I am trying to mesh the airfoil face its giving negative area(mesh is going inside the airfoil) and skewness >98.
I am using MAP scheme to mesh the face.
If you want I can send the dbs file.
parvez2683 is offline   Reply With Quote
Old   June 19, 2009, 01:54
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
post a picture of your issue, with a zoom in your issue.
If you enable the shade-option, is the interior of the airfoil also shaded?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 24, 2009, 00:49
Default meshing problem in NACA0012
parvez
Hi MAX,
I have attached the zoomed in(shaded) file of my problem.
After Using shade option it shades only the outer part not the inside of the airfoil.
Old   June 24, 2009, 01:46
-mAx-'s Avatar
Maxime Perelli
Try to split the outer surface along the x(x<0) axis.
And remesh both surfaces, it should help
[Commercial meshers] NACA0012 meshing problem parvez2683 OpenFOAM Meshing & Mesh Conversion 0 June 18, 2009 23:03
Boundary layer meshing problem in Gambit Crystal FLUENT 0 June 12, 2009 21:58
problem meshing in GAMBIT khairul hadi Main CFD Forum 1 August 20, 2008 18:13
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 21, 2006 00:31
Problem meshing very thin pipe B. Hemmen FLUENT 2 May 16, 2006 09:29
