[GAMBIT] Help needed with meshing!
Old   June 5, 2009, 11:48
DT
fluentnoob is on a distinguished road
Oh. Ok. Thanks a lot. You are a life-saver -mAx- !
fluentnoob is offline   Reply With Quote
Old   June 5, 2009, 21:11
Post help needed for meshing a 3D fuel slinger
  #22
eers
eers is on a distinguished road
Hi
I really don't know how to start 3D meshing of a slinger..it's bit a complex geometry with lot of holes and edges..I created this model in solid works and imported to gambit as iges file..could any one suggest me the approach in gambit..I have done the tutorials in gambit and but not fully understood all the tools..Thanks in advance for your help..
eers
eers is offline   Reply With Quote
Old   June 6, 2009, 16:42
DT
Hi Max! Thanks a lot. I subdivided the domain and the mesh just worked fine. I have one more query though. When I just had a look at the boundary layer, the skew of the highest element was .92, and when I had a look at the volume mesh ( with the boundary layer attached) the highest skew was .75. Is this normal for it to vary this much?
Also, do you by any chance know about Error Code 101077? I had a few of this in Gambit startup window.
Thanks a lot. You saved me a lot of time. Thank you very much!
Old   June 6, 2009, 18:38
Smile meshing in gambit
  #24
bhupesh
bhupesh is on a distinguished road
i am working on fluent 6.3.26..........for meshing i am using gambit.........i ned help in meshing..........i wantto mesh the geometry withdifferent spacings..........means in critical area i want to do fine mesh and in general coarse mesh to save the memory space..................so please help me........
bhupesh is offline   Reply With Quote
Old   June 6, 2009, 18:41
bhupesh
Originally Posted by eers View Post
Hi
eers
i advise you to follow a simple procedure for volume meshing in gambit.........
curvature, fixed, gambit, meshing, size functions
Marine current turbine (meshing and stimulation help needed!!) coolyihao FLOW-3D 0 March 16, 2009 12:48
Urgent help needed in Dynamic Meshing Rohit FLUENT 0 March 3, 2008 15:17
meshing needed ejazkd FLUENT 0 October 17, 2006 06:02
urgent help needed for meshing in GAMBIT chris FLUENT 0 September 5, 2002 10:18
Problems meshing a pie-shape cross-section bar-suggestions or workarounds needed Ricky Wong FLUENT 1 May 11, 2000 18:35
