meshing of turbine blade
Old   May 30, 2009, 07:23
Default meshing of turbine blade
jay
jayaero is on a distinguished road
hi,
I want to learn turbo machines analysis in GAMBIT and Fluent.....
Anyone who have experience of CFD please help me....
please give me if u have any tutorials (apart from given within softwares)....
I am working for my masters thesis on effect of stagger angle on turbine blade cascade.
Thank you.
jayaero is offline   Reply With Quote
Old   May 30, 2009, 07:33
Default tutorials of turbine blades
sivaramakrishnaiah
sivarama1 is on a distinguished road
Send a message via MSN to sivarama1 Send a message via Yahoo to sivarama1 Send a message via Skype™ to sivarama1
HI,
Give me your mail ID i should send,actually i have pdf format
All the best.
sivaramakrihnaiah
sivarama1 is offline   Reply With Quote
Old   May 30, 2009, 14:10
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
There are two ways of doing this.
1. using Template for turbomachinery i.e. G turbo. This is the easiest way with minimal user input
2. Manual method
Now tell me whichmethod you like.
Far is offline   Reply With Quote
Old   May 30, 2009, 14:45
Default @ sivaramakrihnaiah
jay
@ sivaramakrihnaiah
Thanks for reply.
my e mail id is jaydeeptrivedi03ae47@yahoo.com
Old   May 30, 2009, 14:50
Default @ Far
jay
Thanks for reply.
Does G turbo stands for Turbo tool in gambit.
I would first like to go for easy method as I have less little experience in turbo meshing.
Thank You.
Old   May 30, 2009, 15:16
Far
Sijal
You just have to convert the IGES file into turbo format i.e .tur . and then press some buttons in gambit. your file of turbine/compressor simulation is ready.
That is all you need in gambit and then run solution in fluent
Old   May 31, 2009, 02:07
Default @ Far
jay
Thanks for reply.
I have done gambit tutorials related to turbo tool but since same tuto is not in fluent i am having problems...
I dont know which boundary conditions r to be applied.
I need some tutorial of turbo which guides through both gambit and fluent.
some research papers r there but most of them requires subscription.
do u have any tuto apart frm already given in software?
Old   May 31, 2009, 07:33
Smile
Far
Sijal
you need following boundary condtions
1. Total pressure , total temprature, flow inlet angles at inlet
2. Static pressure at outlet corresponding to required mass flow rate and you need to turn on the radial equilibrium option
3. Fluid speed equal to your rpm (set the rpm as low value and then gradualy increase to required level.
4. Casing is stationary
5. periodic conditions for periodic surfaces
Flow setting
1. Initially 1st order and courant number 1
2. Flow solver coupled implicit (also named as density based in fluent 6.3 and latter)
3. initialize from inlet values
Turbulence model
1. K epsilon
2. SA (I have worked extensively with SA and found to be very accurate)
3. SST
Old   June 10, 2009, 05:38
toto
anat_sri is on a distinguished road
to sivaramakrihnaiah
hi, I need too please
my email is iamnotslave@hotmail.com
anat_sri is offline   Reply With Quote
Old   September 3, 2009, 11:07
kaka
zhh0910 is on a distinguished road
my email is zhh091088@126.com
zhh0910 is offline   Reply With Quote
Old   September 3, 2009, 11:22
sivaramakrishnaiah
hi what you want
sivaramakrihnaiah
Old   September 3, 2009, 11:44
kaka
the pdf that I can learn how to mesh turbo machines
Old   October 29, 2009, 14:39
Pat
toupador
Pat is on a distinguished road
hallo
please may i've got the pdf my mail ist assogbapat@yahoo.fr
thank you.
Pat is offline   Reply With Quote
Old   November 9, 2009, 12:39
Juan
holyo is on a distinguished road
Hello sivaramakrihnaiah, could you send me the pdf? My e-mail: xenxoc@gmail.com
I´m going to make a windturbine meshing and I need learn about it.
Thank you.
holyo is offline   Reply With Quote
Old   November 9, 2009, 22:49
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
@ sivaramakrihnaiah
Can you send me the pdf?? I need it. Thxs
here is my email: huget_teguh@ymail.com
teguhtf
teguhtf is offline   Reply With Quote
Old   November 10, 2009, 23:02
Khaled
Almohammadi is on a distinguished road
Could you please send me the file or any one who recived it.
doctorkms@hotmail.com
Thanks
Almohammadi is offline   Reply With Quote
Old   November 13, 2009, 05:32
Default Turbine Tutorial
  #17
sivaramakrishnaiah
Hi all,
I am sending link here download,
http://www.4shared.com/file/15125741...ade_fuent.html
sivaramakrihnaiah
Old   November 14, 2009, 15:40
Pat
toupador
think you for the file
Old   November 22, 2009, 23:48
Alberto
Alberto1987 is on a distinguished road
I have to simulate something like this for the University and it can be useful for me.
Thanks in advice
lopezflorenciano@gmail.com
Alberto1987 is offline   Reply With Quote
Old   November 22, 2009, 23:55
sivaramakrishnaiah
welcome,
All the best for your bright future.
Are you from
sivaramakrihnaiah
force acting on gas turbine blade.... vvj Main CFD Forum 1 March 3, 2010 02:04
Q: how to do a good meshing in turbine usin gambit oscar FLOW-3D 1 March 15, 2009 00:15
Question on blade meshing Jeffrey CFX 0 March 7, 2008 18:13
Flow study through Turbine Blade passage Subrata FLUENT 1 May 4, 2007 12:28
Meshing pitched blade turbine Racheal FLUENT 0 July 12, 2005 14:25
