[GAMBIT] STL file import into Gambit
Old   May 8, 2009, 10:12
Default STL file import into Gambit
Ibo
Ibo
Ibo is on a distinguished road
Hi
I’m trying to import an STL file into gambit. But I cannot get any volume out of it, and I'm stuck of what to do. Can anyone help me please
Kind Regards
Ibo
Ibo is offline   Reply With Quote
Old   May 15, 2009, 06:48
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Did you try with STEP?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 15, 2009, 07:00
Ibo
Ibo
Max
It's a STL file gained from CT scan data. how can I convert it to STEP file?
Many thanks
Ibo
Old   May 17, 2009, 17:46
Default Options?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Is your faceted geometry closed? It will need to be closed. I don't know if GAMBIT has the required repair tools, but other ANSYS Meshing tools do.
Do you also have access to ICEM CFD? If so, you could repair the facets and mesh it there. ICEM CFD is very good for medical scan data...
Do you have access to TGrid? You may be able to do the repairs in TGrid also. Import it as a mesh and use the diagnostics to locate (and then repair) all the single and multiple edges, or import it as a faceted geometry and use the shrinkwrapper to get a nice surface mesh.
Once you close all the single (and remove multiple) edges from the model, it will be a nice volume model and GAMBIT should take it (or you could just finish up the volume meshing in ICEM CFD or TGrid).
PSYMN is offline   Reply With Quote
Old   May 18, 2009, 01:58
-mAx-'s Avatar
Maxime Perelli
Originally Posted by Ibo View Post
Max
Many thanks
Ibo
I thought you was able to import STEP.
Anyway, I was already faced to same problem while importing STEP file.
The issue was, that my volume in ProE didn't have any mass properties.
Once you imported your STL file, did you try to stitch faces for creating a volume?
how can i import igs file in gambit? Javier FLUENT 2 May 23, 2011 11:51
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 18:33
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 05:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
import *cas file from fluent to gambit?? Rashmi FLUENT 5 October 25, 2005 02:18
