April 19, 2009, 17:29 |
Meshing for eppler423
Vishnu
What kind of meshing is required for eppler 423.If c-mesh is required can anyone explain the kind of procedures like meshing of its edges.whether it is first length, successive ratio etc. for its edges?
April 20, 2009, 02:39 |
Janarthanan Alagesan
Rep Power: 17 |
Hi Vishnu,
For airfoil flow analysis C - type mesh is widely used. In some cases like rounded trailing edge O - type mesh is more suitable. I assume you are using E423 airfoil with sharp trailing edge. You can use first length, last length, successive ratio or the combinations of all, but all depends on how you split your edges and how you want to distribute the points on the airfoil surface. The important factor is more points are needed at the leading edge and trailing edge. So use trail and error method to find the best option. Cheers, Alagesan. |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 12:03 |
Meshing locks workbench window. | andy2o | CFX | 0 | February 1, 2008 06:01 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 21, 2006 00:31 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 12:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 12:08 |
