April 8, 2009, 05:50 |
Import CGNS in Gambit
Rep Power: 17 |
Hello everybody.
I have recieved various meshs from the SNECMA, where only NUMECA softwares are used. They would like to compare the results they have with calculs made on another code. the problem is : none of the files they send me can be opened on gambit. Only the CGNS could be, but, unfortunately for me, it doesn't work. the only things i managed to do, are to open the cgns file in Fluent (then I've tried to export it into various formats, none of which could be opened into gambit) and in Icem, were i find it impossible to export the mesh or the geometry into whatever format supported by Gambit or Fluent. Could somebody tell me how to make it work? any idea would help me a lot. Thanks in advance. Last edited by Harkot; April 8, 2009 at 06:19. |
April 8, 2009, 06:43 |
Maxime Perelli
Rep Power: 41 |
Did you tried to open it in fluent, write the case file and import the *.cas into gambit (import/mesh/Fluent)?
April 8, 2009, 07:06 |
Rep Power: 17 |
i did try that, with no results what so ever : gambit just won't open it
April 27, 2009, 11:29 |
Rep Power: 17 |
I still am in a tight spot :s
could anybody help me please? i have searched as many info as possible on this forum, without finding anything helpfull. thanks in advance the best solution would be to find a program which could extract the geometry from the CGNS (iges for instance) thanks in advance |
April 27, 2009, 15:00 |
Maxime Perelli
Rep Power: 41 |
Provide one of the file.
I can try, but without guarantee....
In memory of my friend Hervé: CFD engineer & freerider |
May 21, 2009, 02:44 |
Rep Power: 17 |
Try importing the *.msh file in Ansa and then in Ansa you can extract surfaces from the mesh and thus you can obtain geometry. This geometry might have some flaws however this works.
Procedure File->Inputs->Fluent Mesh tab->Elements->To-Surf Alternate way is try importing *.msh in ICEM CFD and then you can extract surfaces By Tab edit -> (mesh-> Facets) ----option |
May 21, 2009, 17:58 |
Rep Power: 17 |
oh i'll try that, thanks a lot!
@mAx : sorry but I can't pass you over the file, it's against the terms of my contract, but thanks you for offering |
May 22, 2009, 16:41 |
ICEM CFD choices
Simon Pereira
Rep Power: 47 |
In ICEM CFD you have several choices…
If it is unstructured (or structured for that matter), you can simply import the mesh, and then select the output format as “STL”. The output will dump the surfaces as a faceted geometry format that both GAMBIT and TGrid can use… You could also convert the facets to geometry and export the faceted geometry as STL… You could also take that STL geometry into FE Modeler (free if you have the Workbench platform with DesignModeler) and “skin it” and convert it to a Parasolid. This is very interesting functionality new with 12.0. In ICEM CFD, if it is a structured Hexa mesh and you have the domain files in ICEM CFD, you can choose Edit (from the top menu next to file) => “Struct mesh -> CAD surfaces”. Then use “File => Export Geometry” to Parasolid or IGES or Rhino3D… |
Gambit Import error | GUEST | FLUENT | 7 | May 30, 2019 12:46 |
SketchUp 3D model import to Gambit or Fluent | Steve Johnson | FLUENT | 0 | February 8, 2009 15:21 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
export or convert gambit mesh to CGNS | zaidun | FLUENT | 6 | April 20, 2006 05:48 |
Autocad import into Gambit | Paul | Main CFD Forum | 5 | July 12, 1999 05:19 |
