Solidworks --> Gambit
Old   October 9, 2000, 18:05
Default Solidworks --> Gambit
Sandeep
Any tips on importing geometries from solid works to Gambit. (without having to do much cleanup).
Most of my geometries are NOT extremely complex so I can draw them directly in Gambit. However I also have the solidworks files so I was wondering if I could save time by directly importing them in Gambit. I have tried that couple of times, but I have had to spend lot of time in clean up and utlimately ended up spending the same amount of time as in drawing from scratch.
Any tips ? Any other CAD packages that work better than solid works ?
Thanks in advance
Old   October 10, 2000, 00:04
Default Re: Solidworks --> Gambit
Trac
Hi Sandeep,
I imported a fairly complex geometry from Solidworks to Gambit via acis and it worked great. It came in as 8 separate volumes, as in the original file.
Tracie
Old   October 10, 2000, 13:01
Shyam Kishor
As mentioned by Tracie, the most preferred option would be to write an ACIS file from Solidworks and import that in Gambit. You can also use Parasolid format as the next preferred option. Please make sure to check the geometry in Gambit after import, and use "healing" to improve its accuracy, if needed.
Old   October 25, 2000, 11:57
Daniel Malone
I operate a business, CAD Repair, that specializes in helping get neutral files into software cleanly. If your models are not to complex then I can probably do it very cost effective for you.
Dan Malone www.cadrepair.com dpm@cadrepair.com 412-820-9205
Old   February 24, 2011, 15:34
Default importing solidworks gometry into gambit
himanshu aggarwal
himanshuagg1991 is on a distinguished road
Originally Posted by Trac
;95154
Hi Sandeep,
Tracie
i tried the same thing but an error occurs
"file:///F:/K/Gambit/workk/wheel%20k.IGS"
"ACIS error 52005:save file is from a later version of acis."
and i am using solidworks 2010 for designing
please suggest me a solution to the problem
i would be really grateful
himanshuagg1991 is offline   Reply With Quote
Old   February 25, 2011, 02:31
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
did you try to import a IGS File or an ACIS FIle?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 26, 2011, 14:35
himanshu aggarwal
i have tried both ,
when i do import-->iges and the try to open the .igs format , and the error is --" import iges -F:\\gambit\\workk\\wheel k.igs scale 1 spatial tolerant.
Translation requires license feature geom-trans
translation failed "
and when i try to import-->acis and then try to open .sat file , the error is
"import acis -F:\\gambit\\workk\\wheel k.sat" ascii
'ACIS error 52005 :save file is from a later version of acis'
Old   February 27, 2011, 02:37
zaky mubarak
barak182 is on a distinguished road
u can convert it to *.igs
barak182 is offline   Reply With Quote
Old   February 27, 2011, 04:15
Unhappy
himanshu aggarwal
this is what i am trying to say ,,
when i save the solidwork geometry in .igs format and open it in gambit , error occurs
Old   February 28, 2011, 03:17
-mAx-'s Avatar
Maxime Perelli
and if you try to import step file?
Old   January 17, 2014, 08:53
Lightbulb This thread is dead but...
  #11
Tim
timB is on a distinguished road
In case anyone is looking up this thread later on, I have found that imported ACIS/.sat files work well with Gambit, where parasolid/.x_t files work well in the ANSYS DesignModeler program. The two geometry/mesh programs use different graphics engines. And as a best practice, eliminating as many translations as possible will yield the best results. For example, importing a .sat file into ANSYS DesignModeler will result in a file that was first translated into a parasolid format and then translated again into a DesignModeler file.
I don't know if Gambit is supported anymore by Ansys and Fluent, but I suspect that it isn't. Ansys has its focus set on stitching Fluent into its workbench environment. They're making progress with each version, but there's still work to be done. The Ansys workbench mesher is still more of a mechanical (FEA) mesher than one suited for CFD grids in my opinion.
But I digress... So, it may be harder and harder to deal with Gambit as the 3D CAD packages continue to develop. However, at the present time, you can export .sat files to earlier "ACIS-standard versions". I think ACIS version 10 works well with Gambit v4. If you need to export to parasolid, I would go back as far as your CAD program will allow with a file that looks right.
timB is offline   Reply With Quote
Old   August 15, 2015, 05:39
Unhappy solid to gambit
  #12
mostafa
pesar125 is on a distinguished road
i tried to import 3D from Solidworks to Gambit with GIS format
but when it imported i didn't have volume
When i wanted to convert all faces to volume, an error occured
How can import my 3D Solid to Gambit?
With other format (parasolid, step, acis ) error occured!!
My Geometry so complex and i can not draw it in gambit
pesar125 is offline   Reply With Quote
Old   August 17, 2015, 03:05
-mAx-'s Avatar
Maxime Perelli
*what kind of error occured with step ?
*with IGS I assume you need to clean the surfaces and connect them for generating volume.
check here:
https://www.sharcnet.ca/Software/Gam...guide/tg05.htm
Old   August 17, 2015, 03:55
mostafa
ERROR: Translation requires license feature gem-trans.
Old   August 17, 2015, 03:57
-mAx-'s Avatar
Maxime Perelli
the message is clear: you don't have the required license for importing cad
Old   August 18, 2015, 00:11
Default license
  #16
mostafa
I know that!
but How can i get the license?
What am I gonna do to do my project?
Old   August 18, 2015, 02:06
-mAx-'s Avatar
Maxime Perelli
you still have the possibility to import IGS file.
Again:
https://www.sharcnet.ca/Software/Gambit/html/tutorial_guide/tg05.htm
export 2d model from solidworks to gambit bad080boy Main CFD Forum 2 April 29, 2011 15:31
Problem importing solidworks to gambit holyo ANSYS Meshing & Geometry 3 April 16, 2010 06:16
problem importing solidworks file into gambit mzack1104 ANSYS Meshing & Geometry 4 September 17, 2009 12:27
SolidWorks to Gambit Chris FLUENT 0 November 6, 2005 18:15
Plot3d grids > Gambit > Fluent 5 David C FLUENT 1 February 16, 2001 17:29
