October 4, 2024, 06:32 |
Surface to solid body
Francesco
Hi everyone, i have a problem with Ansys design modeler. I have to analize flow around an ultralight airplane. The input geometry file is a STEP one and the model was export from SolidWorks as a solid body. The problem is that Ansys sees it as a surface. I tried a lot of methods (fill, extrude, repair, curve gap, thin etc ) to solve this issue, also in spaceclaim ambient but nothing happened and without a solid i can't use the boolean operation "subtract" to create my domain and then create the mesh and do the analysis. Could you help me please? It's for my thesis for university
October 4, 2024, 07:04 |
Gert-Jan
Rep Power: 28 |
- Since your tried different ANSYS tools, it looks like the export is from Solidworks is the problem. Or did you also try other software?
- Add pictures. That mostly helps a lot. |
October 4, 2024, 10:38 |
Francesco
Hi..Yes i tried other softwares like catia. I imported the file on catia and exported it as step, stl and other types of files but Fluent always sees it as a surface. The problem is that the other softwares sees it like a solid, while Fluent doesn't
October 6, 2024, 07:01 |
Gert-Jan
Rep Power: 28 |
Who is complaining? Was it Design modeler? But now you mention Fluent?
Are you on the route to Fluent Meshing or to ANSYS Meshing? Please share a picture. A picture says more than 1000 words. |
design modeler, surface & solid bodies |
Error in gmshToFoam on ESI v2106 | siefer92 | OpenFOAM Programming & Development | 4 | July 17, 2021 06:11 |
Surface bodies to solid body. | KLA | FLUENT | 2 | February 18, 2020 08:48 |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 13:50 |
[DesignModeler] Merge Surface Body and Solid Body | prikeyma | ANSYS Meshing & Geometry | 5 | April 16, 2015 08:01 |
[DesignModeler] Can't get a surface body with positive thickness from a solid | kobylkinks | ANSYS Meshing & Geometry | 0 | March 25, 2015 05:07 |
