[ANSYS Meshing] the problem is "u can delete the single edge elemengts"
Old   September 26, 2024, 00:43
Default the problem is "u can delete the single edge elemengts"
zhangqifan
zhangqifan is on a distinguished road
Hi,my friends,i have a problem in icem meshing.The problem is "u can delete the single edge elements,put them in a new subject:Single edges" when i check mesh.
So,what metods can solve this problem,please!
zhangqifan is offline   Reply With Quote
Old   September 30, 2024, 04:28
Gert-Jan
Gert-Jan will become famous soon enough
I guess the problem is somewhere in the geometry.
If you put the edges in a new subset, you can make them visible quite easily. So, it will tell you where the problem is and where you have to work on the geometry.
If you need more help, please share a picture of the geometry and the subset.
Gert-Jan is offline   Reply With Quote
[cfMesh] Edge problem momod OpenFOAM Community Contributions 1 May 23, 2024 09:31
[blockMesh] Problem with C-mesh for aerofoil with single, 6 vertex block montju OpenFOAM Meshing & Mesh Conversion 3 July 11, 2022 06:04
[GAMBIT] GAMBIT edge problem SJD ANSYS Meshing & Geometry 4 February 26, 2014 16:56
Through-Flow solver, Leading-Trailing edge problem Menander Main CFD Forum 0 May 14, 2008 19:14
trailing edge problem Kuo Wei-Jen Main CFD Forum 2 April 14, 1999 11:09
