[ANSYS Meshing] Convex edges and inflation
Old   September 23, 2024, 10:57
Default Convex edges and inflation
svantevid is on a distinguished road
I'm using Ansys Meshing (in Workbench) to create the mesh.
I'm having some difficulties in creating inflation on the border between 2 bodies. I managed the fix the inflation on the green body (image bellow) by increasing the maximum angle setting, but I cannot fix the inflation on the grey part.
What I tried so far (without success):
- define inflation with both bodies together
- different sizing on all the edges, connected to the problematic part of geometry
- shared topology
Image:
svantevid is offline   Reply With Quote
Old   September 24, 2024, 03:39
Gert-Jan
Gert-Jan will become famous soon enough
In the sticky notes, on top of the list of queries, you can find how to include images in the posts (see internal link below), instead of using links to external websites which I won't open.
https://www.cfd-online.com/Wiki/Ansy...n_the_forum.3F
Gert-Jan is offline   Reply With Quote
Old   September 24, 2024, 04:29
Thanks for the tip, I edited the original post.
Old   September 24, 2024, 05:00
Gert-Jan
The bodies are not connected correctly. Do you use Spaceclaim or Design Modeler?
Old   September 24, 2024, 05:41
Spaceclaim.
What do you mean by not connected correctly?
If you are referring to the non-conformal mesh, it is on purpose because I had some convergence problems when doing a similar geometry in the past. I also tried with Shared Topology functionality and conformal mesh, but the problems were the same, see bellow.
Old   September 24, 2024, 09:57
Erik
evcelica is on a distinguished road
There could be a geometric problem with the smaller sharp body. (small hidden edge?)
Seems weird to not have a conformal mesh here?
Is this one single fluid volume or two separated by a solid interface?
can you use a conformal mesh (share topology) then mesh the larger body first, then the smaller sharp one? Or does that not make a difference?
evcelica is offline   Reply With Quote
Old   September 24, 2024, 10:36
I checked again, no hidden edges, small faces...
Single fluid volume but it's divided, one is a stationary and the other is rotary part - I'm doing an analysis of a centrifugal pump.
I tried your strategy, but couldn't get it to mesh.
Is it possible that the geometry of the sharp part is just too problematic for the inflation layer to grow from the surface?
Old   September 24, 2024, 11:04
Managed to solve the problem by changing the border shape between bodies.
edge mesh, inflation
[snappyHexMesh] Resolving Trailing Edges of Airfoil in sHM sfluck OpenFOAM Meshing & Mesh Conversion 4 April 17, 2024 09:15
[ANSYS Meshing] Inflation does not affect the expected edge perotto94 ANSYS Meshing & Geometry 1 July 6, 2023 08:44
[ANSYS Meshing] Inflation on 2 perpendicular edges to size cells Haaziq ANSYS Meshing & Geometry 0 November 30, 2022 13:51
[ICEM] How to specify inflation layers around a curved surface in ICEM CFD? murali666 ANSYS Meshing & Geometry 0 August 31, 2022 06:34
[ANSYS Meshing] Problems with creating a hex-uniform MultiZone Mash with Inflation AnnaF ANSYS Meshing & Geometry 4 April 19, 2019 07:24
