[Other] The boundary layer in SC Meshing
Old   September 12, 2024, 08:23
Exclamation The boundary layer in SC Meshing
Eugeniy
Caparison is on a distinguished road
Hello, friends. I need your help to build a boundary layer with y+=
1.
So I created an internal volume on Dy200 and the same length. I started to figure out why a negative volume is obtained with the following parameters:
The number of layers is 25
The height of the first cell is 0.01 mm
The degree of growth is 1.2
I made a small volume on purpose to understand which parameter to change to increase the angle.
And what I saw in the picture. Why does only the entrance edge have red cells, but the back one does not? Is this some kind of bug with SC Meshing or am I doing something wrong?
Caparison is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
[snappyHexMesh] Error defining boundary layer around cube snappyHexMesh crizpi21 OpenFOAM Meshing & Mesh Conversion 5 October 16, 2021 11:56
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Boundary Layer Mesh must cover the whole thickness of BL sasanghomi CFX 2 June 11, 2019 22:16
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
