[TurboGrid] Error in Exportpoints in BladeModeler |
September 5, 2024, 09:46 |
Raj
I have a shrouded blade axial flow compressor, which I have made using Solidworks & Exported to Ansys Designmodeler where I have done all the steps until Flowpath creation(Defining Inlet, Outlet, Hub, Shroud). When I do export points there is an error and the following message is displayed. I have attached the warning & my geometry below. Can any one help me sort this out?
ansys, blade modeler, design modeler, meshing, turbogrid |
Changing problem of LE and TE while transporting from blademodeler to turbo | Ensar Yazgan | ANSYS | 1 | April 21, 2020 01:49 |
[BladeModeler] Blade ExportPoints & Hub/Shroud Offset | gdimitris | ANSYS Meshing & Geometry | 1 | July 3, 2018 13:59 |
[BladeModeler] Unwanted Solid body creation in ANSYS Blademodeler | taaresh01 | ANSYS Meshing & Geometry | 0 | January 9, 2018 05:49 |
[DesignModeler] FlowPath & ExportPoints Addin? | Norflow | ANSYS Meshing & Geometry | 3 | April 19, 2016 07:14 |
tutorials on Blademodeler | Muhammad Qureshi | CFX | 3 | April 7, 2008 12:58 |
