[DesignModeler] Error while importing coordinates file using 3D Curve in Design Modeler |
August 31, 2024, 09:30 |
Rep Power: 2 |
Greetings everyone, I am facing an error whenever I try to create a curve using the "3D Curve" option in Design Modeler. The error says:
'Error: Reached the maximum number of curves allowed for the curve feature Context: Curve Feature Curve2 File: D:\Nozzle_MOC_Caps\WT_Nozzle_MOC\Circ_Arc\Simple\c oordsdm.txt Line: 2000" Any help on this is very much appreciated! I have also attached my text file here |
September 6, 2024, 09:14 |
#2 | |
Edee O'Hare
Rep Power: 12 |
Hi, I checked your file and got the same error. If I reduced number of points to 1950, it worked, so there might be some limit of points one can import using coordinate file. |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 03:52 |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
