[TurboGrid] Export as CAD from turbogrid/bladegen |
August 2, 2024, 09:48 |
Johan M
Rep Power: 5 |
Good day,
I would like to know if there is a way to export a CAD geometry of the solid regions from a periodic turbogrid/Bladegen impeller? I intend on using that geometry for an FSI. I did find a blade geometry from one of the directories in the dp0 folder but I would ideally like to be able to export the geometry with its hub/shroud curves Kind regards, Johan |
export geometry, fsi 1 way, turbogrid |
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 | bjdarrer | OpenFOAM Installation | 7 | August 25, 2020 19:15 |
[foam-extend.org] foam-extend-4.0 gcc errors & maybe paraFoam | powerline332 | OpenFOAM Installation | 3 | May 24, 2018 21:16 |
A CFX-POST error (ver 14.5.7) | wangyflp88 | CFX | 2 | July 22, 2017 00:17 |
Unable to install OpenFOAM 1.6-ext | Maimouna | OpenFOAM Installation | 23 | May 8, 2014 05:47 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
