[Other] BladeGen -local change of geometry only (radial pump) |
July 25, 2024, 08:27 |
Primož
Rep Power: 2 |
I am trying to apply LOCAL SWEEP and LEAN change of geometry to my radial pump rotor. Problem is, that with changing leading edge at shroud I get the change to whole blade at shroud, downstream. My goal is to only change it locally at leading edge (at shroud) and then to relatively quickly transition back to original geometry downstream. I would be really grateful for any insights how to do that in BladeGen. Is there an option to define how quickly modified part of blade goes back to original geometry (sort of locking certain flowpath length in meridional view)? Uploaded picturtes: -two pictures of how I achieved sweep and lean at meridional projection window -two pictures to compare, as an example of how changing loaction of point T2 on shroud affects trailing edge change-which I can not avoid yet. So my main worry is to stop trailing edge from changing angles and to localize sweep/lean effect as much as possible to leading edge at shroud. Thank you all for your help! Primoz |
July 25, 2024, 16:19 |
Changing layer 1 trailing edge theta value
Primož
Rep Power: 2 |
So far I managed to come closer with changing theta value (on trailing edge of layer 1) to value of my base geometry rotor.
bladegen, geometry, lean, radial pump, sweep |
Fluent UDF for Radial Motion of Pump Geometry | Syaida21 | ANSYS | 0 | June 7, 2024 10:10 |
actual PUMP GEOMETRY, using vista cpd | abdg | CFX | 3 | July 4, 2018 08:57 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 07:09 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
