[Other] [Fluent Meshing] Poly-hexcore boundary layer mesh around a wing sharp trailing edge |
July 24, 2024, 10:00 |
Stuart
Rep Power: 26 |
Ansys Meshing has a parameter called Maximum Angle (default = 140 deg) if Global / Inflation / View Advanced Options = Yes, to help wrap inflation layers around sharp features.
I'm using Fluent Meshing for a poly-hexcore mesh on a wing with a sharp trailing edge, but the boundary layer elements are failing at the sharp trailing edge. Fluent Meshing does not have an option like the Maximum Angle (above). Anyone been able to get a successful poly-hexcore mesh around a wing with a sharp T.E.? PS, I was avoiding using a baffle from the TE downstream to grow the boundary layers on, they would form stair-stepping at the end of the baffle (OK) but extend Y+=1 elements downstream into the wake (not ideal), but that might be the only way. |
Volume and Surface mesh taking a lot of time | ghost_rider1145 | FLUENT | 0 | March 20, 2024 11:36 |
flow over cylinder in openFoam | saeed jamshidi | OpenFOAM Pre-Processing | 3 | August 11, 2023 15:16 |
[snappyHexMesh] How too improve y+ number at trailing edge and Wing tip | AlbatrossR | OpenFOAM Meshing & Mesh Conversion | 3 | October 18, 2021 03:33 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
