[ANSYS Meshing] How to avoid unnecessary wall creation between parts |
Arun raj.S
Rep Power: 16 ![]() |
Dear all,
I am working on printed circuit heat exchanger. in order to achieve good meshing, i split the one part into multiple parts. however, in this case, i am getting unnecessary wall creation between parts. Even i grouped all the parts in the named selection under a single name, the walls are created unnecessarily between the individual parts, which actually must be interior. however, to overcome such issues. can grouping parts, help to get rid of these wall creation. |
Erik
Rep Power: 23 ![]() |
Sounds like you need to "create part" if using design modeler or use shared topology if using Spaceclaim. Then the mesh at the intersection will be a conformal mesh with shared nodes at intersections between bodies.
Arun raj.S
I divided one component into multiple parts as it accelerates meshing in parallel mode. By doing this, I am getting wall created in between the parts. I thought of converting these walls into interior.
Erik
It accelerates meshing because they can mesh however they want, and not have to conform to each other, (and they can also mesh in parallel). But you also lose accuracy as well since grid interfaces would have to be used in between these dis-similar meshes. I would use a conformal mesh if possible.
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Enhanced Wall Treatment | paduchev | FLUENT | 24 | January 8, 2018 11:55 |
Avoid creation of bad cells while decreasing distance between parts? | kg1913 | ANSYS | 0 | September 5, 2014 06:05 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
