[ICEM] too many nested evaluations (infinite loop?) |
July 3, 2024, 21:15 |
Zhe Li
Rep Power: 5 |
Dear Engineers.
I am currently working on a simulation project on Air-levitation platform, however when I am trying to use ICEM for mesh generation, I got the following error:too many nested evaluations (infinite loop?). This occurs while I am linking the edge of the blocks to the curve of the geometry. Why would this happened and how can I fix it or avoid it? Thank you very much! PS: I am using Ansys 2019 R1 |
July 4, 2024, 06:10 |
Marcin
Rep Power: 13 |
This error message in ICEM, encountered while linking block edges to a geometric curve, indicates a potential issue with the way you're defining the link. Here are some possible causes and solutions:
Causes: Circular Dependency: The linking process might be creating a circular dependency between the edges and the curve. This could happen if the definition of the link relies on information derived from the linked entities themselves. Incorrect Selection: You might be inadvertently selecting multiple edges or curves during the linking process, creating a loop. Software Bug (Less Likely): While less common, there's a slight chance this error could be caused by a bug in the specific version of ICEM you're using (Ansys 2019 R1). Solutions: Simplify Linking Logic: Review how you're defining the link. Avoid relying on information from the linked entities within the link definition. Double-check Selection: Ensure you're only selecting the intended edge and curve during the linking process. Check for Over-Constraints: Make sure the linking doesn't create any over-constraints on the geometry. The linked entities should have the necessary degrees of freedom to maintain a valid mesh. Try Alternative Linking Methods: Explore alternative ICEM linking methods like "Match" or "Project" to achieve the desired connectivity. Consult Documentation and Forums: Refer to the ICEM documentation or online forums for specific examples and troubleshooting steps related to linking edges and curves. Consider Upgrading (if applicable): If you suspect a software bug, consider upgrading to a newer version of ICEM if feasible. Newer versions often contain bug fixes and improvements.
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
MPI Reduce operator in the parallel calculation of a nested loop | peyman.havaej | OpenFOAM Programming & Development | 0 | August 3, 2021 08:33 |
Need help setting up chtMultiRegion | OskarT | OpenFOAM Pre-Processing | 1 | September 25, 2019 15:51 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[ICEM] "too many nested evaluations infinite loop" Error | alienplanet | ANSYS Meshing & Geometry | 3 | February 10, 2012 05:31 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
