[DesignModeler] Whats the official way for creating flowpath? |
June 15, 2024, 04:31 |
Mohsin
Rep Power: 3 |
I have an axial compressor rotor 37 geometry. I want to create hex mesh for that using turbogrid. I am trying Flow path and Export points method.
But while generating exportPoints it always fails. The reason is my flowpath is not accurate enough. I tried increasing the hub/shroud Offset % to as high as 40 but its still not working. Is there any official documentation about it? that how can we produce flowpath for our geometry? I have attached my designmodeler file. Any help would be greatly appreciated. |
bladegen rotor37, design modeler, turbogrid errors |
Porting viscoelasticFluidFoam to Official OpenFOAM | xuegy | OpenFOAM Programming & Development | 2 | May 26, 2022 04:29 |
[DesignModeler] Define FlowPath for axial turbine | giangcoikx | ANSYS Meshing & Geometry | 1 | September 29, 2016 19:06 |
[DesignModeler] Problem with FlowPath and ExportPoints | stessigunn | ANSYS Meshing & Geometry | 15 | July 24, 2016 15:28 |
[DesignModeler] FlowPath & ExportPoints Addin? | Norflow | ANSYS Meshing & Geometry | 3 | April 19, 2016 07:14 |
[DesignModeler] Error with FLowPath for centrifugal compressor | sidharath | ANSYS Meshing & Geometry | 0 | June 2, 2015 06:20 |
