June 5, 2024, 10:11 |
ICEM pits in mesh
Maciej Janiszkiewicz
Hello everyone,
I am trying to learn ICEM and I am looking for a reason of specific problem. With more or less correct blocking, I can see a lot of pits in my mesh that shouldn't appear (please see pictures included). Could you give me a tip what should be improved? I have checked other tolerances and slightly different blocking, but it didn't help much. Thank you for all tips in advance |
June 6, 2024, 03:55 |
Gert-Jan
Rep Power: 28 |
Does your geometry contain geometric curves? And are these associated to the edges of the blocking? Make sure this is the case.
June 7, 2024, 10:01 |
Hi Gert-Jan,
After a doublecheck, I confirm that edges are correctly associated. Could you think of any other reason of these pits? I am working on mesh quallity (determinants 2x2/3x3/ ortagonality/skewness etc) but it seems areas with these pits have OK mesh quallity. |
blocking, icem, meshing, pits |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
ICEM of ANSYS V15: how to export .msh mesh for CFX | hydroaero | CFX | 1 | March 9, 2015 22:15 |
[ICEM] Generating mesh for modified parts in ICEM without changing mesh of other parts | a.habibi | ANSYS Meshing & Geometry | 5 | October 4, 2012 05:10 |
