May 29, 2024, 14:13 |
ansys meshing
vahid
Rep Power: 2 |
Hello everyone,
I am meshing two completely identical parts in the Ansys meshing software, in each corresponding line, two parts of the same number of division and in each face, I have used face meshing and the hex domained method, the mesh is perfectly suitable in the upper part, but in The lower part of the mesh has a problem and I can't fix it. Thank you for your help.In addition, by changing the method to multizone mesh, it gives an error. https://filetransfer.io/data-package/M3Xph6Wz#link https://filetransfer.io/data-package/srA58DDA#link Last edited by vahidbarati447; May 30, 2024 at 09:07. |
#ansys, #mesh, #meshing, #structure mesh |
[ANSYS Meshing] ANSYS Meshing Problem | Saikat_FM | ANSYS Meshing & Geometry | 1 | September 15, 2016 02:25 |
Mesh difference between 14.5 version and 15.0 version in ansys meshing | sunxihui | ANSYS Meshing & Geometry | 0 | May 6, 2014 04:22 |
ANSYS 2D Meshing | The Engineer 2014 | ANSYS Meshing & Geometry | 0 | March 26, 2014 20:54 |
[Other] Ansys Meshing vs Ansys ICEM CFD | JuPa | ANSYS Meshing & Geometry | 5 | September 19, 2012 09:48 |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
