December 20, 2023, 10:07 |
DM Geometry Update file access
Rep Power: 6 |
I have connected a (parameterised ~ 10 geometric parameters) CAD file with Cadnexus to a Design Modeler block within the Workbench. I also wrote a script which creates a given number of Design Points and assigns each DP a specific value for its respective geometric parameters. My problem is, that if I update all parameters of a given DP at once, it can happen that the Geometry update fails. That's why the script, for a given DP, assigns the first new parameter value/expression, updates the geometry, assigns the second new parameter, updates the geometry, ... My question is, which baseline/initial geometry file/state is used here? Is it the currently (partly) updated Geometry which is gradually updated and the respectively updated version is used for the next update etc., or is always the baseline geometry (in my Case the "Current" DP) used? Thanks a lot! Version: 2022R1 |
cfd, designmodeler, doe, parameter study, workbench |
[openSmoke] LaminarSMOKE compilation error | mdhfiz | OpenFOAM Community Contributions | 8 | July 2, 2024 10:32 |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
