[ANSYS Meshing] Ansys Fluent volume meshing gets stuck |
December 14, 2023, 17:20 |
Hello, I have a problem with meshing in Ansys Fluent. The calculation always gets stuck at 39% at the point "Processing tet refinement for poly" , when creating the "Generating the Volume Mesh" and does not change for hours (Second Screenshot).
So also I have noticed this tends to happen, when one of fl_mpi2310.exe processes cpu usage is decreasing to 0% (First Screenshot). I'm runnig parallel version with 12/28 cores and without double precision. Please help( |
Ansys Fluent Meshing Prism Split | CFDger | FLUENT | 1 | July 29, 2022 04:43 |
Calculating source term total cell-zone volume parallel computation | RobV | Fluent UDF and Scheme Programming | 2 | May 30, 2022 03:46 |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[ANSYS Meshing] Ansys Meshing equivalent of Fluent meshing wrapper | evevev | ANSYS Meshing & Geometry | 0 | February 1, 2018 21:50 |
