[ICEM] bloc
Old   September 22, 2023, 14:56
Default bloc
Prabhakar T R
prabhakar_tr is on a distinguished road
in 3D meshing baffle has 1mm thickness, is necessary to remove block inside the baffle, if yes why?
prabhakar_tr is offline   Reply With Quote
Old   October 13, 2023, 09:27
Chrowale
mluckyw is on a distinguished road
It is not necessary but there's a practical reason for it:
1. If you only focusing on something around the baffle and does not need the mesh inside of it then the simulation will be lighter in a sense there's no need to compute those area.
2. It's an easy way to get the mesh to have an association to nearest surface, you just need to associate the edges and vertices and you are most likely done.
If you want to get the mesh in the baffle region, you could create a different part name for it and it will detect that it is a different block and create a surface association to nearest surface automatically
mluckyw is offline   Reply With Quote
blocking
[blockMesh] Problems meshing a half of a cylinder with blockMesh zfaraday OpenFOAM Meshing & Mesh Conversion 2 December 11, 2013 04:41
[blockMesh] CheckMesh error using a tutorial from OpenFOAM 114 with openFOAM 13 martapajon OpenFOAM Meshing & Mesh Conversion 7 January 21, 2008 13:52
Problem with InterFoam in_flu_ence OpenFOAM Running, Solving & CFD 4 October 26, 2007 09:39
meshpilot Bounecer Main CFD Forum 2 October 8, 2006 05:16
Tutorial bCavityb case problem wells OpenFOAM Installation 2 March 21, 2005 08:55
