[ANSYS Meshing] The mesh file exporter could not resolve cyclic dependencies in overlapping |
September 11, 2023, 02:46 |
AmirMehrdar
The mesh was imported correctly, but I encountered this error while updating the mesh. "The mesh file exporter could not resolve cyclic dependencies in overlapping contact regions. Please try to Repair Overlapping Contact Regions." I intend to perform a thermal analysis on a gas turbine blade using ANSYS Fluent software, where the geometry includes: blade geometry, internal cooling channel geometry within the blade and domain In the simulation, I considered three domains, so that in the middle domain, the hot gas impacts the airfoil surface, while in the upper and lower domains, there is regular air. The geometry was Booleaned in the following order: First, the blade geometry from the domains.Then, the cooling channel geometry from the domains. "What is the correct procedure for Boolean operations in this simulation?" How can I resolve this error? The geometry image has been attached. |
October 13, 2023, 07:45 |
Geetanjali Alle
Rep Power: 3 |
hi, could you solve this problem? I have the same difficulty
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
