[ICEM] Operation in progress bar not visible sometimes |
July 31, 2023, 06:46 |
Anonymous
Rep Power: 4 |
Hi everyone, sometimes the Operation in progress bar doesn't appear when trying to smoothen the mesh elements in ICEM CFD. It's not a grave issue, but sometimes when I'm trying to smoothen a large number of elements, this progress bar is the only indication that the process is going on and that the ICEM is not stuck in the background.
Is it something with my screen resolution or some settings I forgot to turn on(or off)? |
August 1, 2023, 06:00 |
Gert-Jan
Rep Power: 28 |
In my 20 years of experience with ICEM, I have never ever observed something similar.
Did you see the same problem in older versions? Since ICEM is no longer maintained, it might not be able to keep up with latest updates of your operating system. |
August 1, 2023, 06:08 |
Anonymous
Rep Power: 4 |
I have only used ICEM CFD in ANSYS 2020R2 for the past year. So I'm not sure about the previous releases. My PC is running Win 10 Pro, so there may be some inconsistency.
I have never tried to change the screen resolution to see if this issue persists. I will try that. |
icem 3d, mesh 3d, mesh qualty |
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so | immortality | OpenFOAM Pre-Processing | 15 | April 7, 2024 13:35 |
Fluent Simulation: Progress bar doesn't show in Work bench | Souma | FLUENT | 0 | October 27, 2020 01:39 |
Progress Bar for loading a file thru UI | DMalone | STAR-CCM+ | 0 | March 7, 2020 11:51 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 07:47 |
Incompatible dimensions for operation | ruben23 | OpenFOAM Running, Solving & CFD | 2 | June 12, 2015 05:14 |
