[DesignModeler] Fill a solid square with hollow spheres. |
July 27, 2023, 17:15 |
Alim
Hi. I am a complete beginner at Ansys. I want to fill a solid square with hollow spheres. The patterning doesn't work here. I even tried doing each hollow sphere manually(Primitive->Sphere->Cut Material), but that doesn't work. What would be the effective approach to filling a solid square with hollow spheres?
July 31, 2023, 06:32 |
Create spheres and subtract using boolean
Anonymous
Rep Power: 4 |
Create spheres as frozen bodies apart from the square block (solid).
After patterning the spheres according to your requirement, use boolean subtract to remove the volume occupied by the sphere from the square block. You will get hollow spheres in a single solid square block. |
Edge removal after solid fill hole python script function | akkidivate | ANSA | 1 | October 19, 2020 06:57 |
chemical reaction involving gaseous reactants and solid product | sara137 | Fluent Multiphase | 0 | June 21, 2020 06:26 |
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam | xpqiu | OpenFOAM Community Contributions | 8 | June 17, 2015 03:08 |
Immersed solid, vs solid-fluid interaction to determine forces on a submerged solid | amrbekhit | CFX | 0 | January 8, 2015 17:39 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
